Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 01-08-2006, 02:50 AM
uibalnme uibalnme is offline
Still no overdrive
I posted this topic before(12/03/05), but I only got one reply(12/04/05). So, here we go again. I have an 89 pickup w/ a 22RE(225,000 miles) and auto trans. A few months ago it just stopped shifting into overdrive. The fluids were new at the time and at the proper level. I changed the fluids and it still wouldn't shift into overdrive. No leaks or any visual problems. Then I had the trans replaced and still the same thing. What could be the problem? A sensor, faulty wires, vac. leak, torque converter? It's still strong from 1st to 3rd, just no overdrive. I've run out of ideas. Can anyone help me?
Old 01-09-2006, 07:37 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Typically, there are sensors that inhibit OD until the engine is warm, below certain speeds, etc. that could be bad.
Torque conv is a possibility.
Bad connection/broken wire to tranny (not getting L/U signal)
Bad solenoid in tranny.
You may need a competent tranny shop (hard to find), not one of the rip-off tranny chains.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-09-2006, 05:44 PM
imc188222 imc188222 is offline
Re: Still no overdrive
The first thing to check is the overdrive switch itself. That and the wiring associated with is the most likely problem.
Old 01-09-2006, 08:05 PM
O/D soleniod was changed out with the old trans. I'll have to check all the wires then. If I can't find anything I'll just have to go to AAMCO. Thanks for the ideas guys.
