Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-08-2006, 01:03 AM
mitsutuner13 mitsutuner13 is offline
Send a message via Yahoo to mitsutuner13
Exclamation please help with timing belt
i have a 95 eagle talon tsi fwd. i bought the car to play around with and noticed the timing belt was getting frayed on the inside closest to the block. it seems that the belt is riding on the lip on the inside of the tensioner pulley, but i have no idea why. i have replaced my tensioner pulley, both cam gears, and idler pulley. im running out of things to do..this is the third timing belt this month. can somebody please help me or give me any suggestions? any help will be greatly appreciated!
Old 01-09-2006, 11:19 PM
can somebody please help me out??
Old 01-09-2006, 11:29 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: please help with timing belt
Check the crank sprocket and make sure the plate between crank sprocket and balance shaft sprocket is there, if not that could be causing it to ride up on the tensioner and the balance shaft sprocket.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-10-2006, 12:20 AM
the crank pulley is sitting too close to the block...i just noticed that..its in closer than any of the other pulleys (its not lined up with any other pulley)....the plate i see behind the crank pulley is a brass color...is this the plate that you are talking about?? or is there supposed to be another plate?
Old 01-10-2006, 10:43 PM
ez1286's Avatar
Re: Re: please help with timing belt
Yeah, thats the plate. Is the balance shaft sprocket on the crank still on?
Old 01-10-2006, 11:09 PM
yes its there, what should i look for now? and thank you very much for your help so far..i need to get this car fixed...its my daily driver
Old 01-11-2006, 10:55 PM
ez1286's Avatar
I can't think of anything else that could be missing. Maybe the crank sprocket is on backwards? Other than that I can't think of anything, sorry.
Old 01-11-2006, 11:09 PM
this doesnt sound like a crankwalk problem does it?
Old 01-11-2006, 11:11 PM
ez1286's Avatar
No, crankwalk wouldn't cause anything like that.
Old 01-11-2006, 11:35 PM
is there supposed to be a cover over my balance shaft belt? i thought if there was , then it might space it back some. because my car doesnt have a cover over the bs belt
Old 01-12-2006, 11:34 PM
and could there possibly be a shim or washer of some sort behind the pulley that needs to be there, because mine doesnt have anything besides the brass spacer
Old 01-13-2006, 12:41 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Do you have the Haynes manual for the car?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-14-2006, 12:06 AM
yeah
Old 01-14-2006, 01:48 AM
ez1286's Avatar
Do you have the crank key in? I don't think it would run without it but it might. It's a small oval piece that goes into the crank to ensure the crank sprocket turns with the crank.
Old 01-14-2006, 01:52 AM
is this key something i can see without the motor apart? i have the timing belt off....should i be able to see the key? is it supposed to be behind the pulley or where? and thanks for the help so far i really appreciate it.
