Old 01-07-2006, 11:00 PM
lcfd_firemedic lcfd_firemedic is offline
97 Chevrolet Z71 Suspension Problem?
I have a Chevrolet 1500 Z71 and have a problem with the wheel jerking. When going in a curve to the right the right tire or something jerks in turn makes the steering wheel jerk. This is a problem because if not paying attention it jerks enough to make the truck very erratic on steering. It dosent do it when making left curves, and also I noticed that it especially does it when in a long curve. If any one has any suggestions what this could be and about how much this would run to repair, your help would be appreciated. Thanks.
Old 01-08-2006, 09:20 AM
79403ta 79403ta is offline
steering
mine did this and it ended up being a leaking power steering hose and it was causing air to get into the system and also run low on fluid...
Old 01-08-2006, 10:22 AM
Current Resident Current Resident is offline
Re: 97 Chevrolet Z71 Suspension Problem?
Check your ball joints
Old 01-09-2006, 11:13 AM
MyTOY's Avatar
MyTOY MyTOY is offline
A common prob. is the steering sensor.
If you search the forum you will find part #
and detailed replacement instr.
