Old 01-07-2006, 09:15 PM
groundhogg groundhogg is offline
Angry bogging
I have a 94 f-150 with a 302 engine.a lot of miles on it but it was a free gift from a friend.the truck look's great but it wont let you drive it because it bogg's down to bad to even drive it. it will idle pretty smooth,and rev's up o.k. till i get into high rpm's.but when i tried to drive it , it has no power.i already cut off the whole exhaust system from the cat back. I NEED HELP WITH THIS ONE. CAN SOMEONE HELP ME PLEASE!!!!!!!!!!!!!!!!!!!!
Old 01-07-2006, 09:45 PM
85lolo 85lolo is offline
Re: bogging
take off the cat also, could be pluged, happens all the time
Old 01-12-2006, 11:32 PM
Re: bogging
soo ahh what did you find out??
Old 01-15-2006, 05:24 AM
rum runner rum runner is offline
Re: bogging
catalytic converters can stop up but usually just burn out. Replace air filter, fuel filter, spark plugs, add a can of Sea Foam to next fill-up
Re: bogging
Old 01-18-2006, 10:55 AM
hazy303 hazy303 is offline
Re: bogging
My 89 f-250 w/460 bogged up hills and I found out my distributor gear was sheared off but was still running.....also check your fuel pressure and fuel pressure regulator with a high pressure fuel tester on the fuel rail. Idle only reqiures 30lbs, but under load you need near 45lbs, so you could have either a bad low or high pressure fuel pumps. also check that your spark plugs are in the right firing order, that also f*#ks up the power real quick....hope this helps.
ps Harbor freight sells a $11.00 high pressure fuel tester
