Old 01-07-2006, 07:55 PM
evo78 evo78 is offline
stock
hi i got a problem hope u all can help me in this i have a subraru wrx sti and i do not want to spray it because the stock is blue in colour so can i still make it shining by using clear coat, compound and wax thks.
Old 01-07-2006, 08:06 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
The Tamiya kit? Yeah, they did go through a lot of trouble to match the WR Blue in the plastic color. You can give it a nice shine just by rubbing it out with Tamiya rubbing compound. Scrub it with a toothbrush and dishsoap first, then polish with compound. You can add wax afterwards, but it probably won't do much to improve the appearence.
By the way, you'll get much better milage around here if you use proper capitalization and abandon chatboard shorthand. Most of us here are adults- and even if you're not, if you act like one, we'll treat you like one. Act like less, and you run the risk of being blown off....
PHOTOBUCKET SUCKS
Old 01-07-2006, 08:29 PM
ok i have the tamiya the 3 level compound coarse,fine and finish will that do
Old 01-07-2006, 08:35 PM
speedphreak speedphreak is offline
Re: stock
Im curious about this too. Could you sand the body with 2000 grit, clear and polish? Clear would be Testors Custom Laqcuer System 2 part from the can. Sorry to hijack the thread.
-Chris
Old 01-07-2006, 08:46 PM
MPWR's Avatar
Re: stock
That'll do nicely. You'll definately have a shine after that.
You could sand it and clear coat it, but if your not using clear to protect paint, why bother with it? Polished plastic will be just as shiney. I'd leave everything I could unsanded. Mold lines I'd deal with using sanding sticks, and then a Squadron type polishing stick.
Polished plastic can be given a blazing shine, and it's much easier than polishing paint or clearcoat.
PHOTOBUCKET SUCKS
Old 01-08-2006, 04:12 AM
cham2020's Avatar
cham2020 cham2020 is offline
Send a message via ICQ to cham2020 Send a message via MSN to cham2020 Send a message via Yahoo to cham2020
Re: stock
some tamiya kits stock colors are nice and gloossy already...show some pics
Evo Rocks !
