Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 01-07-2006, 06:43 PM
cordor73 cordor73 is offline
Sonoma Starting Problems
I have a 98 sonoma with a 2.2 L. Half the time i go to start my truck it starts fine. The other half it wont start right away. I hold the key for about 5 seconds and the truck wont fire up. Then i stop and do it again about 5 seconds later and it fires right up. After it fires up sometimes the engine surges a little. I havnt waited to see if it stalls out i just always press on the gas lightly until the surging stops. Oh and it doesn't start/not start at any particular times. Sometimes it doesnt start after it sat for 8 hours and sometimes it doesnt start after it sat for 5 minutes. Any help would be greatly appreciated. Thanks
Old 01-14-2006, 02:44 PM
noma96 noma96 is offline
Re: Sonoma Starting Problems
hey i am having the same problem with my 96 sonoma 2.2 L. if the truck doesnt run for 8 hour then it wont start. I then have to jump the battery becasue it drain when im trying to start it, eventually it fires up and runs fine. I took it to my mechanic, both of use went over it changed everything we thought was wrong but it has spark the fuel pump runs its getting fuel but still no solution.
Old 01-15-2006, 08:29 PM
Kevins1955 Kevins1955 is offline
Love cars
Unhappy Re: Sonoma Starting Problems
Hi all,
I need to add a 98 Sonoma with 2.2 Litre and 5 speed as a vehicle that won't start. The truck ran fine yesterday, but today it will just crank, but not start. Now my truck has 200k miles, so it doesn't owe me anything.
How do I check to see if it is fuel or spark that is causing me this problem?
Thanks,
Kevin
Old 01-15-2006, 08:33 PM
Love cars
Hi all,
Thanks,
Kevin
Old 02-10-2006, 06:04 PM
James Bailey James Bailey is offline
I am having the same problem with my '93 Sonoma with a 2.8. Like yours, just holding the key for a few seconds and it will start. The truck will do this for a few days then work fine for several days. I have also noticed that sometimes my clock and radio have lost power. Right now it won't start at all.
Old 02-12-2006, 08:08 PM
99Montana 99Montana is offline
I had a similar problem with my 97 Sonoma 4.3 - it turned out to be a cracked coil. Easy fix but annoying at the time. I was coming up on a 100K so I figured I couldn't go wrong by changing the plugs,cap,rotor,and wires too
08 GMC Sierra Ext Cab Z71 4wd 5.3 (wife's ride!)
02 GMC Sonoma Ext Cab 4wd 4.3
99 Pontiac Montana Ext 3.4 SOLD to the out-laws!
99 Chevy Silverado Ext Cab Z71 4wd 5.3 'plowboy' SOLD!
Old 08-16-2006, 01:10 PM
ronsbicycleworks ronsbicycleworks is offline
I have a similar problem with starting. I pause before hitting starter to let the fuel pressure build back up (allow fuel pump to run for seconds), then it starts. My gm mechanic son suggests that It could be the backflow valve in fuel pump or check valve in the fuel injector system allowing pressure to bleed off when not running.
