Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-11-2002, 11:38 AM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
What's the point???
I understand that if you drop the compression ratio within your cylinders you can run more boost therefore creating more horsepower. But I am running into a conceptual block here. If I drop the compression in my cylinders, but then crank up some more boost, aren't I ending up with the same pressure within the cylinder that I had before I dropped compression?!?
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 06-11-2002, 11:59 AM
swedish swedish is offline
Nope, here's the deal, (this is a 100% volumetric efficency), a N/A engine pulls in air and compresses it (along with fuel) 10-11-12 (:1) times. When you run boost at 8:1, your commpressing the 6-12 psi 8 times. This would make it seem that you might as well run 3 psi on a cheap setup, but with boost and lower comppresion, the engine isn't working as hard as low boost and higher commpresion.
"One great big festering neon distraction,
I've a suggestion to keep you all occupied.
Learn to swim."
Old 06-12-2002, 10:01 PM
pvang31019 pvang31019 is offline
all the rage nowadays is running high compression and lower boost....
the lower compression is just there so that you have a larger window for tuning error
Old 06-17-2002, 06:25 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
I'd personally rather have lower compression and be able to boost higher.
95 Integra GS-R
[email protected]
what's the point??? gw84 Lumina 9 08-02-2006 04:04 PM
CL65, what's the point?? raven1822 CL 24 07-04-2005 11:44 AM
What's the point of the carbon fiber hood anyways? Gateway 3000GT/Stealth 3 09-14-2004 04:01 PM
What's the point of those "fart pipes"? 328isRob Stress Release 22 02-06-2002 12:59 PM
