Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-07-2006, 04:49 PM
gooddad gooddad is offline
Question oil loss - engine seized
My son's 95 talon tsi lost it's oil filter last night and the engine seized. the mechanic who works on the car says that's been know to happen on these cars. Actually, the shaft that holds the oil filter on came loose and spins. Any thoughts on how this could have happened? I think he is full of crap and wasn't paying attention. The filter was loose last week and a new filter was put on; it 's then when he said this has been known to happen; we only lost a couple of quarts that time and were lucky. I don't think he looked into the problem deep enough considering how critical oil is to the engine. The shaft where the filter connects tho the engine is spinning freely which is why the oil was lost this time and the engine seized. If this were a common problem everybody would be talking about it. Again, what would cause this to happen??? I've been driving for 37 years and I've never seen this happen on any car, anytime! thanks!
Old 01-08-2006, 12:09 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: oil loss - engine seized
I've heard it happen once before but I guess its happened quite a number of times and alot of them were caused my incompatant mechanics who weren't paying attention when they changed the oil. I'd take it to the shop (if thats where the oil was last changed) and tell them what happened and who ever did the change is liable and they owe you a motor it sounds like
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-08-2006, 03:12 AM
SLoe's Avatar
SLoe SLoe is offline
Never heard of it.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 01-08-2006, 10:39 AM
blk_srt's Avatar
Re: Re: oil loss - engine seized
Originally Posted by loeman
Never heard of it.
There was a guy that posted hear a couple months back that took his eclipse to a jeffy lube or some place like that and they didnt tighten the oil filter and his motor seized and he ended up with a new motor out of the deal. I'll see if I can find the link
Mods:
Old 01-08-2006, 10:45 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I don't think it's a problem with this cars, only incapable mechanics. The screw to the oil filter can be tightened and if the mechanic knew it was loose it's his fault.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-08-2006, 01:54 PM
It's not really a problem of him knowing how to put on a filter but when it had happened once before and we lucked out I think a good service mechanic should have investigated it thoroghly. If so, he would have found the problem and we would still have a running engine.
My main purpose behind the post was to find out if this was a common problem with eclipses or talons as he stated. Since the members on this forum have considerable experience with these cars...I hoped to get some feedback.
Old 01-08-2006, 03:13 PM
blk_srt's Avatar
Like ez said its not really a common problem with our cars but more like a problem with the installer. If the same thing happened before and you took it to the same mechanic and he didnt fix the problem in question it is his fault for not finding the root cause of why it came loose in the first place
Mods:
Old 01-10-2006, 09:49 PM
ez1286's Avatar
Re: Re: Re: oil loss - engine seized
Regardless of whether or not it is a "common problem" your mechanic should have seen the problem when he did the oil change. He is at fault and should replace the engine, if he won't do it get a lawyer.
