Old 01-07-2006, 04:22 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Fuel pump advice
I'm going to be upgrading my pump soon and I thought about being cheap and just buying a 190 but I thought I might as well just go ahead and get a 255 and a megan racing afpr. My question is should I get the normal 255 or a high pressure version?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-07-2006, 06:07 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Fuel pump advice
What are you planning on running for a turbo and injectors?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-07-2006, 07:04 PM
blk_srt's Avatar
well, by summer I would like to have a 16g and 650cc injectors, but in the future theres dsm link, a 60 trim, and 980cc's
Mods:
Old 01-07-2006, 09:04 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
I havn't heard anything about the Megan AFPR. Does it have the ability to raise & lower fuel pressure?
DSM geek
Old 01-07-2006, 09:22 PM
blk_srt's Avatar
http://www.slowboyracing.com/shop.php?sid=&cat=4056
Looks like it does the same thing as an areomotive but its cheaper and comes with a gauge
Mods:
Old 01-07-2006, 09:55 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Re: Fuel pump advice
just because it looks the same, dosen't mean it is. there is NO replacement for the aeromotive unit. i think alot of Wisemen can back me up on this one.
if your going do buy a 255 or a 255hp do it right and get the aeromotive fuel pressure regulator. it will also make tuning on DSMlink a hell of alot easier with a solid fuel map. if you get the AFPR get the high pressure 255, no reason not to....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 01-07-2006, 11:58 PM
blk_srt's Avatar
Well megan racing is a trusted name and I've only heard good things about their products, but I know what you mean aeromotive is the best but if the megan racing unit is as good as the rest of their products then at this point since im poor its the route that I'm going to go down. before I do anything however I'm going to find out as much as I can about it and make a decision based on fact and not just looks
Mods:
Old 01-08-2006, 12:34 AM
97_3clipse's Avatar
yes, please do research, hate to see a nice car burn to the ground because of a flaw in the fuel system....
Old 01-08-2006, 11:48 AM
Quickly searching on Tunners, a few people have it, and it works just fine. Slowboy Racing think it is a good AFPR, but don't recomend it over the Aeromotive unit untill they can make a 1g & 2g install kit.
Megan racing is an up a coming company out of So Cal, it seems like they're allways coming out with somthing new every month. Their chrafrsman ship is quite good! But I would prefure to wait and see what this FPR will hold up to when it becomes more popular. Fuel is to important to be a ginnypig subject on their first generation regulators. Megan racing has a tendency to mass produce probamatic parts. (2g gsx downpipes)
DSM geek
kjewer1 kjewer1 is offline
AF - Advisor
If the choice is between a 255LP and a 255HP, always go with the HP. There really is no choice if you ask me. There is no advantag to the LP version. The pressure at idle is the same depsite popular internet rumor, since the only real difference is a higher pressure relief valve. And you'll have the AFPR either way!
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-08-2006, 03:19 PM
blk_srt's Avatar
Thanks for all of the great info. Now that I know which pump I'm going with, the question lies in which regulator, the tried and true aeromotive unit or the less expensive possibly flawed megan racing one. on paper they both seem really good but since the megan racing one hasnt really been used a whole lot its kind of iffy
Mods:
Old 01-08-2006, 04:42 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
aeromotive FPR, it's proven. Or if you don't have the cash for a good FPR, you can do what I'm doing. I bought the 190 and I'm running that since it pumps out enough fuel for most 50 trims and definitely the evoIII. Once I get something massively bigger I'll buy a 255 and a FPR, the pump itself is only 90 bucks, so not that huge of a deal.
now - 2000 civic
soon - 2002 is300
Old 01-08-2006, 05:44 PM
blk_srt's Avatar
Thats a good point and probably what I will end up doing since cash is short and I want to have lot of other things done by summer. I just figured if I could get away with a 255 and regulator for $170 I'd do it now
Mods:
Old 01-08-2006, 07:22 PM
You can keep your eyes out for the Aeromotive 13109 on ebay for $129 shipped..
DSM geek
Old 01-08-2006, 09:29 PM
AF - Advisor
The EVO8 pump is a touch bigger than the walbro 190, and it was NOT sufficient to run the EVO8 turbo, fyi. On the stock wiring, I was out of fuel around 35 lbs/min, which is exactly what my fuel spreadsheet predicted. With the pump rewired its good to around 42-44 lbs/min, which is exactly what you will get out of an EVO turbo, maxed out of course. For a 50 trim that is capable of 50 lbs/min, the 190 is too small unless you only plan to max it out on race, but even runner leaner on race gas may not buy enough headroom. My opinion is that you don't want to be riding the limit on your fuel system setup. One mishap with boost and damage can occur. I lost my last motor on the 11.3@126 pass because I was on the 255 LP. The HP would have been enough, and I could have run much faster before the end of the season. In fact it was because of that last failure that I learned 75% of everything I know about fuel systems...
Kevin Jewer
