Go Back   Automotive Forums Car Chat > BMW > Technical
Old 01-07-2006, 03:58 PM
styly styly is offline
Unhappy high temperature reading
i have a 1996 bmw 320i with the 2l vanos engine i lost a lot of my engine coolant and since this happened my temp gauge has been reading high with warning light on then quickly droping back to 3/4 or 1/2 it so eratic that im wondering if it is faulty .
the water level is fine im also thinking there could be somthing wrong with the thermostat as the temp is changeing so rapidly could a stuffed thermostat cause this problem as well.
well hope someone can tell me if i on the rite track or not any thoughts would b great .
Old 01-22-2006, 09:09 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: high temperature reading
Sounds like you got a bad stat. If you loose too much coolant it is not very good. Check for over boil, leaks from the pump,water in oil (foam), etc.
Old 03-09-2006, 01:34 AM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
If the car has overheated the Thermostat does need to be changed. You need to pressure test your cap and radiator. Also tried to bleed the radiator you may have an air bubble running through the system and messin with the gauge.
Old 03-09-2006, 02:21 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I agree 100% with Tuffdrvr88
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 03-09-2006, 08:51 PM
Thanks Corning_D3, almost forgot what it feels like to be agreed with lol
