| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
2003 Check Engine Light on...
I have a 2003 Pontiac Sunfire, and the check engine light has turned on. I checked the manual and said that it could be an unsecure gas cap (which it wasn't.) When I got my oil changed at an oil change establishment, I asked the attendant to check to see if he can see why the light has turned on. He checked a manual and said that it has to do with a sensor with the Emissions system. I admit, I'm clueless when it comes to cars. Is this a serious, costly problem to fix, and should I leave my car sitting in the driveway...or am I safe to drive my car without doing further damage? I have only had the car for a little over a year, and bought it used, and has 62,000 miles on it. Any assistance would be helpful!!!!
Re: 2003 Check Engine Light on...
get a scanner tool for an OBDII and check for codes depending the code it will tekll u whats wrong with it dont go to an oil change shop go to a place that especializes in that or get u a scanner and retrive the codes in that way u can be sure whats wrong also if ur car doesnt feel like stalling or anything or even overheatting u can keep using it untill is fixed lemme know how u doing with it good luck |
Thanks...I'm probably just going to get it serviced to double check. I am just wondering how much its going to cost to repair a sensor...
You don't "repair" a sensor, you replace them. More than likely its an O2 sensor which is under $10 in parts, but its labor that'd give you trouble with the cost.
1992 Chevrolet Cavalier Z24 *R.I.P.* 3.1L MPFI (3.1 6cylinder Pushrod 12V) 1997 Chevrolet Cavalier Z24 *R.I.P.* 2.4L "Twin Cam" (2.4 4cylinder DOHC 16V) 2003 Honda Accord EX V6 - The new hotness |
