Old 01-07-2006, 02:18 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Towing questions
Ok, so Mikes car is a POS. We are just going to rebuild the engine, but theres no garage close by. We've decided to rent a storage unit to put the car in and work on. The only problem is getting it there. It doesnt quite run, it fires, just wont actually run. Will towing it behind a truck be bad for it? We had to have it towed to his house and they had to use a flatbed because its AWD, it was like $80. The plugs were shot, I'm hoping a new set of plugs with let it run enough to drive it a couple miles to the shop. If not then we are going to pull it behind a friends truck, unless its really bad for the car, then I guess we have to bite it and get it towed on the fuckin flatbed again. Thanks guys.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-07-2006, 02:23 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
You have to use the flatbad, you can't tow an AWD vehicle. Hopefully you can get it to run enough to move it a few miles.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-07-2006, 02:31 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: Towing questions
why cant you tow an awd? if you put a tow stap onthe front hook and just go acouple miles doing 20 mph???
Old 01-07-2006, 02:36 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
as long as the car is neutral and someone is steering, I highly doubt that any damage can occur...Just make sure not to go too fast thats all.. GL
Old 01-07-2006, 02:38 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
If all of the wheels were on the ground going the same speed and your in netural I dont see what the problem would be
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-07-2006, 03:38 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
http://machv.com/awdtowdecal.html
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 01-07-2006, 03:58 PM
blk_srt's Avatar
Nice
Mods:
Old 01-07-2006, 06:06 PM
Thor06's Avatar
Jizzed In My Pants
I know that you cant do it on 2 wheels, what I mean is tow it on all 4. Like stated above, just hook up somethign on the front and pull it. Will that work?
Old 01-07-2006, 07:03 PM
blk_srt's Avatar
Re: Re: Towing questions
Well the way I see it is if all 4 wheels are on the ground and you're being towed its basically the same thing as coasting in netural so it should hurt at all
Mods:
Old 01-07-2006, 09:58 PM
Thor06's Avatar
Jizzed In My Pants
Can anyone back this up or say a for sure no? Anyone ever done it? Will just leaving it in neutral and pulling it on all four tires work?
Old 01-07-2006, 10:48 PM
inatalonIXLR8 inatalonIXLR8 is offline
No problems. Just remember that your steering and braking will be difficult without the engine running. Other than that don't let the 5.0 see you and everything will be just fine.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 01-07-2006, 11:33 PM
Thor06's Avatar
Jizzed In My Pants
Awesome. Yeah, we'll be doing it on backroads probably early in the morning or later at night. We still need to look around for a shop (rental storage unit that will be serving as a shop while we pull the engine ) but as soon as we find one, we'll go to work. It will sometimes start for a coupe seconds, atleast enough to let the brakes and steering depressurize or whatever, I'm thinking we'll make it work. I know how we can get from his house to the place that we are most likely going to rent from in about 6 turns. Heh, I know our little town too well . Thanks guys, I appreciate it.
