Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-07-2006, 02:14 PM
g.p. g.p. is offline
ABS Codes
Does anybody know if a OBD2 scanner will retrieve ABS light codes as well?
Thanks,
Greg
Old 01-07-2006, 05:20 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: ABS Codes
If it has the software for the ABS. If it is an inexpensive code reader,it probably will not read the ABS.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-25-2006, 10:21 PM
jd-autotech jd-autotech is offline
Re: ABS Codes
some abs codes are retrievable by grounding the orange/black wire near the e-brake pedal and counting the abs light flashes
Old 01-25-2006, 10:24 PM
Re: ABS Codes
rear wheel drive with rear antilock has flash codes, 4wheel drive with 4 wheel abs you need a scanner and typical cheap obd 2 readers have no abs function
