No Battery Voltage to Starter
My daughter's 1995 318i crapped out again. She said the idle was a little erratic, then the car stalled. The car had been running for about half an hour by that time, so it was at operating temperature and she had no problem initially starting the car this morning. After the stall she could not get the starter to turn over.
I tried to start it, and although the ignition key turns fine, and the dash lights come on, at the third ignition position nothing happens. There is no relay, or solenoid noise, no "clicking" sound...nothing. I have checked the fuses, and they are fine. Yesterday, I took her car for a wash, but was careful not to get too much water on the windshield area above the DME housing. The production date of the car is May 1995, and BMW says that the DME flooding problem was fixed by that production date, but I am still careful about that anyway. Yesterday, I also sprayed a little graphite spray into the ignition because occasionally the ignition key would not turn in the ignition. Now the key turns fine, but could I have damaged the ignition lock set by using that spray? Would that have caused a poor electrical connection in the ignition? This car has been running fine for the last two weeks. Before that, the ignition coil-pack had burnt out on cylinder #2, which toasted a transistor in the DME. The ignition coil-pack has been replaced, and I bought a DME from an auto salvage. I exchanged the EPROM chip for the EPROM chip from the original DME, and all worked well, until today. One other thing, before we bought the car 2 months ago, the starter had been replaced, however, I don't think there is any voltage getting to the starter relay, or the starter now. Any help would be appreciated. Thanks |
Re: No Battery Voltage to Starter
could be the relay, any of the wires, or even the ignition switch crapped out. if you have a meter, would start with voltage drops to be certain that there is or isn't voltage getting to the starter. also check the relay. if all that checks out, is most likely the ignition switch.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle. |
You pretty much explained it yourself.
First check all grounds. Than go to the ignition switch. Then go to the starter solenoid. Dont know about that spray, but most anti-teft devices measure resistance in the key chip and that should not really affect anything. It really sounds like the ignition switch. And what do you call a starter relay. No such thing. Most cars have an ignition switch that does both and the rest is the solenoid's work. What you could do to rule out the ignition switch is to try to hot wire the solenoid and see if it turns over.(maybe use some remote starter thing) You should figure how to do it yourself. Or just see if there is current in there. |
Turns out it was a faulty starter, had a dead spot. Replaced, now everything is fine.....until the next time.
Thanks everyone for your help Singring |
How can a bad starter have a dead spot?
