Starter keeps turning after the ignition is turned off
I suspect it's the solenoid. I drove through a flooded road and figure the solenoid got water in it.
Is the solenoid seperate from the starter? Any help would be appreciated Thanks Tony |
Re: Starter keeps turning after the ignition is turned off
as for your problem id check to make sure, 1 battery has a good charge, 2. the voltage regulator is suppling the right amount of current, 3.the ignition switch is still working, 4. the ignition coil is working, 5. the solinoid is working. after you have checked these, check your idel speed, and make sure your fuel injectors do not have a leak.
on the older truck the solinoid was mounted under the hood, most of todays model trucks(1990-present) sometimes have them mounted on the starter. hope this helps Terrell |
could be contacts in the starter sticking, due to age/wear
try new contacts mine is doing the same thing intermittedly it needs new contacts i know good luck
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
