Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 01-07-2006, 12:07 PM
guitarman98 guitarman98 is offline
Unhappy battery goes dead overnite
I have a 2001 town car and the battery goes dead overnite, have tried removing fuses, but still has a drain on the battery.
Old 01-08-2006, 02:38 PM
Den. Den. is offline
Re: battery goes dead overnite
Did you do ALL the fuses? Obviously there is a current draw after you switch off. A serious one at that.
Do you have a multi meter? Test for current draw at each fuse.
You may also want to try joining crownvic.net and asking there. It's a forum for Panther platform owners and maybe someone can from experience tell you the likely suspects.
Hope this helps.
Den.
(Want safer drivers? Ban cellphones, GPS/NAV, traction/stability Control, backup cams/beepers/parking sensors and radar cruise. That'd be a good start! If you're that bad a driver-WALK!! PLEASE WALK!!)
Old 01-11-2006, 10:12 AM
sreilly77's Avatar
sreilly77 sreilly77 is offline
sounds like your alternator isn't charging the battery after the car is ran. get that checked out.
