Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-07-2006, 10:41 AM
04GTmustang 04GTmustang is offline
Help!!
Alright i got a predator for xmas for a 2004 gt mustang. when i installed the Performance tune and started the engine the rpms bounced a lot and the idle got real rough for about 30 seconds. On some cold mornings the idle with bounce from 1000 to 500 very fast and the engine will almost die i was wondering how i could fix this problem or if it was normal so if anyone could help me out that would be great.
2004 Dark Shadow Grey Gt mustang
Mods: Borla catback exhaust, slp X pipe, 85mm maf intake system, 75mm acufab throttle body and plenum, diablo predator flash tuner.
Best 1/8th ET: 9.2 @ 79.8mph (run was done with horrible traction and without the predator)
Old 01-07-2006, 10:54 AM
BlackGT2000's Avatar
BlackGT2000 BlackGT2000 is offline
Re: Help!!
Did you put premium fuel in or are you still running crap 87?
Old 01-07-2006, 12:19 PM
yea im running 93 in it. I think other people have had this problem but i dunno if it can be fixed or what. it clears up and idles smooth after about 30 seconds im wondering if when i installed the diablo tune it took away my choke cause it only does it on a cold start.
Old 01-07-2006, 12:22 PM
01L2Cobra's Avatar
01L2Cobra 01L2Cobra is offline
Re: Help!!
It sounds like you may have to put it on a dyno and tune it. The Pred. for your car covers too many cars so the tune will not be perfect out of the box. I have to same Pred. you have and my AFR is richer than what you would find on a Lightning. I contacted Diablo and was told if I remeber right to remove 10% fuel.
The ///M stands for Motorsports
Old 01-07-2006, 12:45 PM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
Re: Help!!
Hoestly Pred is damn good chip, but I trust SCT more, I know a lot of people that have installed off the bat with no troubles on SCT's end only the installers.
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 01-07-2006, 12:54 PM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
Re: Help!!
yea SCT is the best. but pred is the next best thing
Old 01-07-2006, 06:10 PM
01L2Cobra's Avatar
Re: Re: Help!!
The best is and has always been a real tune from someone who knows what they are doing. The SCT and Pred. have there place but you still can't beat a profesional tune. Hell I know a tuner that is willing to make it out to the track on his own dime to make sure your car is running like it should and if its not he tunes it on the spot. I have yet to hear of anything like that happening with an SCT or Pred.
Old 01-07-2006, 06:48 PM
Re: Re: Re: Help!!
im talking about a chip not a dynotune
Old 01-07-2006, 08:18 PM
01L2Cobra's Avatar
Re: Re: Re: Re: Help!!
Not to be an ass but you were actually talking about a hand held tuner. A chip is part of the process of dyno tuning a car (unless the ECU is reflashed). Still the best way to get the most out of your car is with a professional tune on a dyno not a hand held tuner.
Even if you are using a Pred. its best to tune it on a dyno. This way you can look at results of the AFR and other things as you are messing with the program. Tuning on the street with a hand held tuner is not safe since you don't have actual numbers to look at.
As far as dynos go I would not recommend not having it done on a single drum Dynojet but rather on a two drum Mustang Dyno. The guy that I would trust to do the tune on my car uses a Mustang Dyno and has it programmed to add in the resistance for the weight and aerodynamics of my car.
Old 01-07-2006, 08:32 PM
Ya i plan to get it dyno tuned but cause im really close to getting my cams im gonna wait cause its pointless to get it tuned then i would need to get it retuned so im gonna wait till this summer and i havent been messing the with A/F cause i dont have a guage i just left it stock from the tune that came with the predator.
Old 01-07-2006, 08:55 PM
01L2Cobra's Avatar
Re: Help!!
It could be as simple as the pred. causing you the trouble. After all you are running a 85mm maf intake system, 75mm acufab throttle body and the AFR from the stock Pred. tune like I said the Pred. is far from being dead on to start with.
Old 01-07-2006, 10:08 PM
Re: Re: Re: Re: Re: Help!!
if you want to get technical there called flashers. and i have to disagree on a stock car a flasher is better. on stock car's(3.8's) they have dyno'ed at 16-18 rwhp.
Old 01-08-2006, 12:50 AM
01L2Cobra's Avatar
Re: Re: Re: Re: Re: Re: Help!!
A pro tuner can get more power out of a car than a generic tune end of story. The stock Pred. tune is utterly useless unless you want to loose power. Here just have a look at how bad it screwed my AFR. I will need to find my dyno sheet showing the run without the Pred. but if I remember right the Pred. cost me around 5hp or more.
Old 01-08-2006, 01:29 AM
Re: Re: Re: Re: Re: Re: Re: Help!!
are you saying SCT is a genaric brand?
Old 01-08-2006, 01:32 AM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Re: Re: Re: Re: Re: Re: Re: Re: Help!!
... hes saying a flash tune in general is a generic tune, compaired to a dyno tune done by a professional.
