Old 01-07-2006, 09:28 AM
Smokincavvy54 Smokincavvy54 is offline
Check Engine light is on and i have the codes
i was drivin around last night my car was fine....i get on the highway and doin like 75-80 and all the sudden my check engine light comes on.....so when i got home i put my code reader on it and the codes are
P0134
o2 Sensor CKT No Activity (Bank 1 Sensor 1)
P0138
o2 Sensor Circuit High Volts (Bank 1 Sensor 2)
can anybody please help me i don't understand it was fine and all the sudden check engine light is on
2001 Cavvy Z24
http://www.cardomain.com/ride/662091/1
Old 01-08-2006, 06:51 PM
quake61's Avatar
quake61 quake61 is offline
Re: Check Engine light is on and i have the codes
P0134
P0138
if u r getting those codes means is the oxygen sensor now
before going to buy it check the wire harness that connects to the sensor to make sure is tight
but is normal for oxygen sensors to go bad after a period of time
get the repair manual from haynes there will tell u how to test it
to make sure is the sensor
if it tests bad then is the sensor
it runs like for 70 bucks at ur local autozone
but try to get the original kind oem
