My 2000 2500 has the telltale whine and all but stalled out accellerating on the highway at approx 2500 rpm. I figure the two things are related but is there anything else I should look at first?
I know it needs plugs and wires but the problem is sporadic and developed suddenly. |
When was the last time you changed your fuel filter?
It's cheap and only takes a few minutes to change.... |
Re: Fuel pump shot?
Could be a fuel pressure regulator.
Re: Re: Fuel pump shot?
Re: Fuel pump shot?
Actually, I just recently purchased the truck and I haven't done much to it . It has 108k miles on it so I figure it needs some TLC. It has a warranty to cover anything major but I know it needs some maintainence. I'm bringing it in on tuesday to my mechanic for oil and tranny service, plugs and wires and whatever else it might need. I was figuring on fuel and air filter but the fuel pump whine concerns me. Fortunately I have a good mechanic who feels bad taking my money.
I may have to leave it for a few days but it will be right when I get it back.
From my experience, the fuel pumps in the late 90s trucks and possibly (never owned one) the 2000 trucks always whined and wasn't a sign of a bad pump. I had a '98 Tahoe which I bought used whose fuel pump whined from the day I bought it to the time the pump died about 50,000 miles later. The reason I knew my pump was dead and something else wasn't the culprit? The truck died and when I turned the ignition to the ON position, there was NO whine.
My guess would be same as those who posted above... you probably have a horribly clogged fuel filter.
![]() 2004 Chevy z71 BF Goodrich T/A KO 285/75/16s. Flowmaster 40 Series exhaust. K&N intake. Stull billet grille. F-150 torsion bar index keys. 800w stereo system.
Re: Fuel pump shot?
Is th fuel filter a PITA on these trucks? I remember spilling gas all over my motor in my old Subaru. Am I going to be covered with fuel since the filter sits so low relative to the rest of the fuel system?
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
Re: Fuel pump shot?
If it needs tune up go for it.
But to check fuel pump. And or Hard to start cold. Check cold start fuel pressure. Check engine running fuel pressure. Check engine running on the road fuel pressure. Then shut it off and watch for fast leak down. Pinch off at rubber part or block off return line and check full pressure. Later V6 and V8 gm engines should have 60-66 fuel pressure. Cold start should be 64-65 lbs of pressure. If you do not have full fuel pressure on a cold start the injectors will not squirt fuel. Do not leave home without it. Engine running should be 60-66 lbs pressure depending on engine load. Full pressure with return pinched off should be 75-85 or more. And if it has a fast leak down after shut off you have a leak. Post back fuel pressure readings. MT
Re: Fuel pump shot?
Unfortunately I don't have a fuel pressure gauge or I'd check it. I figured I'd change the filter today since I have to drive it tomorrow. I need my mechanic to check my transfer case and front diff anyway so while he has it he can check the fuel system and address a few other issues.
I just don't want to be a cause of rubbernecking on the LIE on my way to work. |
Re: Fuel pump shot?
I changed my filter. I'm off to work,so wish me luck
Re: Fuel pump shot?
What a difference! I don't think the filter was ever changed before. The truck is way more responsive and I have to watch my speed on the highway now. It even made the tranny shift better. Today it's at my mechanic's shop for the rest of the neglected maintainance
WooHoo!
