Old 01-07-2006, 01:10 AM
kb3jhp kb3jhp is offline
noise when in 2wheel drive
i bought a 1996 blazer a month ago the 4wheel drive did not work it has 126000miles on it so i took the battery tray out to check the vac acut for the front diff it was rusted up so got it free and the 4wheel drive worked great but after i did this it made this vibrating nois from the frount diff only when in 2wheel if it is making the noise and if i shift it to 4wheel it quits complety then i shift it back in to 2 wheel and is silent for about 10sec and starts agen wat is doing this thanks!
Old 01-07-2006, 02:28 AM
OverBoardProject OverBoardProject is offline
Banned
Re: noise when in 2wheel drive
Welcome to Automotive Forums kb3jhp
If it didn't have the problem before you got the 4wd working my guess is that it isn't disengaging all the way
If you van reach the vaccum pot with the battery still in you might be able to give the cable a push and see if it moves in further
Old 01-07-2006, 08:24 PM
Re: Re: noise when in 2wheel drive
i have tried that before it seems to go in slighty but does not stay one odd thing is that if i pull the trancase lever just a littel it also quits i have put the transmision in netul and still does it put it in low does not do it i am thinking maby the cabel going to the diff do you no wat this cost and wher to get it wat else could it be thanks
Old 01-07-2006, 08:39 PM
Re: Re: Re: noise when in 2wheel drive
also when i start when cold and rev slighty it sounds slighty like a knock or a disel i use penoil full sny and a touth gaurd filter could it be the filter do the touth gards have a check vaulve and if not wat ones do
