Old 01-06-2006, 09:30 PM
KEN_7_4 KEN_7_4 is offline
93 laser 2.0 n/t
about 3 weeks ago my 93 laser 2.0 n/t died. I have replaced the ecu, coil pack, crank/cam sensor, throttle position sensor, plugs, wires, ignition module the thing under the coil pack, thermostate, fuel filter and the alternator went out. I am getting no spark and i have fuel going to the fuel rail but cant figure out how to tell if ithe injectors are working. I have a haynes manual. When it died it overheated and blew a hose of the radiator so i fixed and and it ran again but i lost my power. This car was my work car but now its just sitting in my garage any help on what could be the reason for no spark and possibly while it is over heating? I dont see any water coming from the water pump.
Thank You
Ken
Old 01-06-2006, 09:41 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 93 laser 2.0 n/t
Wow, that sucks. I would go get a can of gas and a lighter, burn the fucker and claim insurance . Just playing man thats a shitty thing to do. Sounds like you've replaced all the ignition stuff I would have suggested. Hows the battery? Can you smell gas coming out the exhaust after you crank it over? Maybe not the safest/smartest way to check for gas, but thats what I would do.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-06-2006, 09:42 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
my car did the same thing it started acting funny and then just lost power. then one day it overheated i thought it was the head gasket took my head off and i was missing vavles
Old 01-06-2006, 10:14 PM
Re:
I have a new battery in the car. I didnt smell the exhaust to see if had a gas smell to it. I did pull a couple plugs from it and they are not wet at all. Should i pull the cover off and see if I have a bent valve or 2?
Old 01-07-2006, 12:35 AM
MexRocket's Avatar
MexRocket MexRocket is offline
i would just to be sure... gives you an excuse to buy a tsi or gsx now =)
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 01-07-2006, 08:23 AM
Re:
Would a bent valve cause it to not have spark or fuel? Im ready to just give up and sell it or part it out. It only has 96,5XX miles on it and its all stock anyone want to make an offer on it and come pick it up?
