Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 01-06-2006, 07:38 PM
richmalex richmalex is offline
cv joint replacement 94 accord need help
I took loose all the nuts, but I cant get the studs to come loose of the axle any ideas
Old 01-09-2006, 12:05 AM
BullShifter's Avatar
Re: cv joint replacement 94 accord need help
Remove axle nut
Remove lower ball joint nut
Disconnect lower ball joint
Remove lower strut bolt
Pull out on caliper while hitting axle with hammer
Pry axle from trans
