Old 01-06-2006, 07:16 PM
Ricky Reynolds Ricky Reynolds is offline
Angry Quitting
My 1991 Blaser will just quit when you are sitting at a redlight or stop sign. It quits in drive or reverse. Anyone have any suggestion?
Old 01-07-2006, 07:54 AM
tahoe44 tahoe44 is offline
Re: Quitting
Is this something that has been going on for a while and has been getting worse or did it just start out of nowhere.
Old 01-07-2006, 09:05 AM
Re: Re: Quitting
About a month ago we went out to go to church and it would not start. I replaced the rotor button and the cap. It started after that. Then it would not start again a couple of weeks later. My son and I had to boost it off and when it started he noticed that the coil was sparking from the coil to the valve cover pan. I replace the coil with a used you that I had. But it still does the quitting.
Thnaks for the reply.
Old 01-08-2006, 02:58 PM
btt
Old 01-08-2006, 03:19 PM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
Re: Quitting
My 92 does that, if i crank the wheel too hard it dies, and sometimes when i put it into gear it dies.
I cant figure out whats doing it.
Old 01-08-2006, 05:48 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
1st, don't use a used coil, get a new one. Do a regular tune up (plugs, wires, and fuel filter) and see how it runs after that. Also check all your vac hoses for dry rot and holes. Spray out your throttle body with carb cleaner as well.
Old 01-09-2006, 07:25 AM
Re: Quitting
I put new wires and plugs less than 2000 miles on them. At each oil change (3000 miles) I spray the throttle body with cleaner. Thanks for the reply!
Old 01-09-2006, 07:27 AM
rlith's Avatar
Ok... Look down your throttlebody... Are the injectors spraying a nice fine cone or do they have a slight drip to them?
Old 01-10-2006, 06:54 AM
Re: Quitting
The injectors are spraying a cone shape flow into the throttle body.
Old 01-11-2006, 12:45 PM
Re: Quitting
I cleaned out the rear ventline from the driver side valvecover, cleaned the TBI real good and it has all stopped, i took the lines off clean them out as well, took it out and the stalling and the hesistation/stuttering has left.
Old 01-11-2006, 12:49 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
A stuck PCV valve or a clogged vent line can cause a problem like this and thats exactly what detroitmuscle had. Also how is you idle motor on the TBI, how is the idle too, does it idle at the correct RPM?
Old 01-12-2006, 07:13 PM
Re: Quitting
I put a new PCV valve in this week and cleaned the throttle body. A friend of mine gave me a used throttle control that I'm going to try tomorrow. Thanks for the reply! I will post on the results.
Old 01-12-2006, 07:20 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Quitting
Replace the coil with a new unit and also check your battery voltage.
Your alternator could be weak.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-14-2006, 08:22 AM
btt
Old 01-14-2006, 08:24 AM
rlith's Avatar
Re: Quitting
Originally Posted by Ricky Reynolds
btt
huh?
