Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 01-06-2006, 04:42 PM
tadef tadef is offline
Engine swap
Will a 2.8L V6 bolt into a 4cyl '89 Trooper (manual trans)? Or would it require modification? Better yet, would either the 3.2 or 3.5 V6 bolt in? Thanks.
Old 04-08-2006, 06:16 PM
Quyinnindenver Quyinnindenver is offline
Re: Engine swap
Yes the 2.8 will fit fine without mounting modifications but there are a few wires that you will have to extend. to make fit. the others will need the monts moved further forward for it to fit.
Old 01-28-2007, 02:48 AM
SPRaYeD9 SPRaYeD9 is offline
Banned
Re: Engine swap
the answer is no, idiot.
Old 02-01-2007, 02:43 PM
Joshuas7schev Joshuas7schev is offline
Re: Engine swap
I believe that the transmissions are different but the motor mounts are the same. I recommend the 3.2 s engine code from a camaro or firebird 93-95
