Old 06-11-2002, 12:57 AM
bc4g bc4g is offline
zdyne ecu
as you know im rebuilding a d16z6 to put in my 91std. is it worth it to get this ecu? is it worth it?
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 06-11-2002, 08:04 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
which zdyne ecu? if you're talkin about the gold...then its probably not worth it unless you're gonna boost...if you're talkin about the 'one-wire vtec'..then that may be worth it for the ease of wiring...
SOLD!
Old 06-11-2002, 12:47 PM
91b16sedan 91b16sedan is offline
Yeah the gold is not worth it unless you are going to run boost. I had the zdyne zc ecu when I had my zc and it was great. I had no problems with it. If you are going for the one-wire ecu I give you the thumbs up.
B16a
Other Mods
14.8 @ 94 mph
Resetting ECU- 1995 Toyota Camry V6 XLE Techniker Camry/Camry Hybrid/Vista 1 07-07-2010 08:42 AM
avoid REV Limiter for 4AGE- BT ECU-6speed MT Petroahorro Sprinter 0 06-18-2010 09:22 AM
avoid REV Limiter for 4AGE- BT ECU-6speed MT Petroahorro Sprinter 0 06-18-2010 09:21 AM
Gear selector error and other ECU mysteries jarl Trans Sport 5 05-02-2010 06:33 AM
Flash ECU, will the car start without? schreib Rodeo | Passport | MU 1 03-15-2010 08:09 PM
