1993 Toyota P/U problem.........
I have a 1993 Toyota P/U with the 22RE engine, and currently have 123,000 miles on it, it's automatic & 4x4.
I had an oil change about 5 days ago and all of a sudden my check engine light came on half way home and has stayed on for the last day and half. I checked the oil level, radiator fluid, tranny fluid, and all is fine. Truck seems a little louder and maybe a bit more sluggish, but I don't know if that's just in my head because of the light being on, and no radio on, listening to every little noise? Today I took off the positive connection to the battery for a couple of minutes to reset the computer, and now the light is off and I took it for a short ride and it did not come back on. Is it possible it was just a dummy light that came on or do you have any opinions of what the problem could be that caused this? Thanks for any opinions, Marc |
Re: 1993 Toyota P/U problem.........
Next time your check engine light comes on, have the codes read. Autozone will read codes for free. The check engine light can come on for a variety of reasons.
Please don't post in multiple forums.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered.
To pull the ECU codes: All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it: http://autorepair.about.com/library/...bl-dtcs-36.htm http://autorepair.about.com/library/...bl-dtcs-53.htm http://autorepair.about.com/library/...bl-dtcs-71.htm http://autorepair.about.com/library/...bl-dtcs-90.htm http://www.off-road.com/toyota/tech/codes/index.html http://lcengineering.com/TechNotes/TechNote12.htm http://lcengineering.com/TechNotes/TechNote13.htm http://www.geocities.com/MotorCity/P...ct/Engine.html http://www.mad-mechanic.com/toyota/t...tml#obtaincode http://www.freewebs.com/th3duke/22RE-ECU.mht http://www.troublecodes.net/Toyota http://members.igateway.net/~pscott/enginecodes.html http://www.autobook.co.kr/data_links...uble_codes.htm http://www.autoshop101.com/forms/h27.pdf http://www.showmesome.info/hilux/inf...E/Page0096.htm http://www.efisakh.narod.ru/at_toyota.htm http://www.usatransdoctor.com/foreigntoyota.htm Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio. Sidney® ™ Repairs tv's,vcr's,home/car audio out of my home E-mail:[email protected] Dartmouth,Nova Scotia Canada 1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 245 000 KM http://www.iwaynet.net/~nesda/May02/May18.html http://www.iwaynet.net/~nesda/SonyAudMod.html http://www.newark.com/product-detail...ge/32-9495.jpg http://www.iwaynet.net/~nesda/June03/June0315.html http://www.iwaynet.net/~nesda/Apr03/Apr033.html |
