Old 01-06-2006, 02:53 PM
Thaddeus Cathedral Thaddeus Cathedral is offline
79 Secondary Coil
What is the official name for the secondary coil for the '79 LeSabre? I have replaced the one on top of the distributer cap, with no improvement, now I need to do the other but I can't find the part on the AdvanceAuto site without knowing the real name for it.
thanks
-thaddeus
Old 01-06-2006, 04:03 PM
maxwedge maxwedge is offline
A990 racer
Re: 79 Secondary Coil
What other coil is there other than the one in the HEI cap, this is coil I assume you replaced already?
Old 01-06-2006, 05:36 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Are you referring to the ignition module or (igniter) located at the base of the distributor? As Max said, you only have one coil on the 79.
By the way, what is your problem, no spark?
Old 01-06-2006, 08:56 PM
yeah...no spark...new plugs, wires, and air filter.
-thaddeus
Old 01-06-2006, 09:05 PM
HotZ28's Avatar
AF Moderator Elite
This would be the part you are looking for, it is called the ignition module or igniter;
http://www.rockauto.com/ref/SMP/SMPD...html?LX301.jpg
Old 01-07-2006, 06:39 AM
auto trainy auto trainy is offline
Also make sure that the spring and the carbon pin (located between the cap and the coil) are in good shape,if it isn't you will not transfer spark to the rotor,good luck and let us know how it works out.
Old 01-07-2006, 08:37 AM
diesel1962 diesel1962 is offline
Hello.Ithink you are looking for the pickup coil.You will have to remove the distributor from the engine.Then remove the drive gear on the shaft.with the shaft removed from the body,You will find a round coil.That explaines why you have to remove the shaft,Because the shaft runs thrue the coil.There are two wires that connect to the iginition module.I replaced one on a 77 Buick years ago.It is not that hard to do.Just make sure that you roll the engine to top dead center before you remove the distributor.Be careful when you remove the distributor from engine block,As not to damage the rubber "O" ring on the distributor body.I think the offical name for the part is Pickup coil,Or Relucter coil.Good luck,Let me know how things turn out...Diesel 1962...
Old 01-07-2006, 09:53 AM
HotZ28's Avatar
AF Moderator Elite
The item diesel1962 is refering to looks like this;
It is called "distributor pick-up"
http://www.rockauto.com/ref/SMP/SMPD...html?LX313.jpg
Old 01-08-2006, 07:38 AM
Thanks for showing Thaddeus what the part looks like.It has been awhile since I have seen one!! I remember the Buick that I worked on had one of the wires broken at that coil.Have a good day!Diesel 1962.......
Old 01-08-2006, 09:03 AM
HotZ28's Avatar
AF Moderator Elite
I had to replace several pick-ups during my life, however many more ignition modules. It could be either of them and it would be a good idea to replace both, but not at the same time. If you do, you will never know which one was faulty. I guess the easier one to replace would be the module since you don't have to tear the distributor apart to do it, and then if that should fix it, just start driving and enjoy the day. You can replace the pick-up later, when you have a nice day, the wife has gone shopping and you have a six pack handy!
Old 01-09-2006, 08:37 PM
Hapynzap Hapynzap is offline
Most major parts stores can check (test) the ignition module for you.
