Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-06-2006, 02:03 PM
mistified mistified is offline
Question low idle, check engine light, choking
Hey Just a quick question.
Recently, I threw in a bottle of STP fuel injector cleaner. Since then the car has been rough, not the tank with the cleaner in it, but ever since. Basically the car almost chokes when you step on the gas in a lower range RPM. You have to rev the car before letting off the clutch or it really feels like how those old GM school buses take off (where it jerks then doesn't then does), although if you put down the clutch rev the engine up and engage the clutch again, its fine in a higher rpm again. It's a 95 talon ESI. also the check engine light decided to come on if it's really rough, and it flashes 5 times before staying on solid. I've changed the spark plugs, air filter and sprayed throttle body cleaner thru the air intake hose. The intake hose looks fine, and all the plugs spark. In idle it varies from 1100 to 600 when it's cranky. It's almost like it's choking and trying to clear its throat?
Any suggestions?
Old 01-07-2006, 02:12 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: low idle, check engine light, choking
Get the code read. Often if you go in to a machanic and ask for an estimate for fixing the problem, they will read the code and give you an idea of what you are looking at for repairs.
By the way, I've heard that using throttle body cleaner in the turbo models is bad for the T.B. I'm not sure if this pertains to the Esi models as well, but thought I would throw you a heads up.
Good luck.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 01-10-2006, 10:48 PM
WrecklessMM's Avatar
WrecklessMM WrecklessMM is offline
could maybe be the ecu had a problem like that except my car was running very rich and wouldnt idle smoothe at all. it would almost stall at startup and wouldnt idle. just a suggestion
Old 01-11-2006, 12:31 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Possibly the fuel filter.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
