Old 01-06-2006, 01:49 PM
gobroncos53 gobroncos53 is offline
Camaro keyless entry programming????
Hello,
I just got a new entry remote for my 97 z28, old one went bad. How do I program the new one for my car? I don't know if it makes any difference, but numbers on back of remote are: GM16207901-5 , Canada:218101368 , MODEL/FCCID:AB01502T . Remote has lock,unlock,panic, and trunk buttons. If someone could help me out with this that would be awesome! Thanks again.
Old 01-06-2006, 02:01 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Camaro keyless entry programming????
One's I've dealt with were hold the lock and unlock for about 7 seconds and then the doors should lock.
hope that helps
Old 01-06-2006, 04:24 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
1996-1997 Keyless Entry Programming
Programming procedure:
  1. Turn ignition switch to OFF position.
  2. Remove RADIO fuse 17 from fuse block.
  3. Cycle ignition switch from OFF to RUN three times within five seconds until the door locks and the hatch release cycle, indicating the Body Control Module is in the Programming Mode.
  4. Press and hold BOTH LOCK and UNLOCK buttons on remote control door lock transmitter for 16 seconds.
    1. Door locks will cycle once, confirming the transmitter code is programmed. The door locks must cycle completely to unlock before proceeding.
    2. Any transmitter code that was previously programmed has been erased.
    3. Body Control Module is now programmed to remote control door lock transmitter.
  5. When programming the Body Control Module to match remote control door lock transmitters, the first transmitter code matched will be stored in memory unless a second remote control door lock transmitter is matched at the same time. If programming the Body Control Module to match a second transmitter, repeat step 4. This must be done before the RADIO fuse 17 is reinstalled.
  6. Ignition switch to OFF.
  7. Reinstall RADIO fuse 17 to fuse block.
NOTE: Always program both transmitters when replacing a lost or damaged transmitter. The first transmitter code programmed will always be in both memories until a second transmitter is programmed within the same sequence.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-06-2006, 05:48 PM
bag91's Avatar
bag91 bag91 is offline
WOW....nice work......
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 01-12-2006, 01:36 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
You can also use the GM part # 16245100-29, since the circuit board inside both remotes is identical.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
