Old 01-06-2006, 10:13 AM
rameier rameier is offline
1991 PA headlights
My PA headlights stopped working yesterday. The sentinal seems to not function. The high beams come on OK, but not the low. Am I missing something here, or is it the twilight Sentinal?
Old 01-06-2006, 02:07 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 1991 PA headlights
Fuse?
Old 01-06-2006, 11:24 PM
Re: Re: 1991 PA headlights
Originally Posted by wrightz28
Fuse?
Thanks, started there. Turned out to be the security system via the ignition module.
Old 01-20-2006, 10:57 AM
jeminyned jeminyned is offline
Hello - I have the same problem with my '91 P.A. - Dims won't work, only the high beams. Just wanted to know what you did to fix it and how much did it cost you? Thanks in advance for any advice/answers you guys can give me.
Old 01-23-2006, 08:30 AM
The lights will come on with the ignition. The security system controls this via the ignition module. We decided to replace the module. During the removal a broken wire was detected and then repaired. Has worked ever since. Saved $300.00 on an ignition module.
Rick
Old 01-24-2006, 07:22 AM
Rick
$300.00!! Geez!! That's a great savings for you, I probably won't be so lucky. Just where exactly would I find the ignition module - under the hood or tucked away deep within the bowels of the dashboard also, and what does it look like? Thanks, jerry
