Old 01-06-2006, 08:55 AM
joehfd joehfd is offline
Engine Problem
On my 95 s10 Blazer the engine is loosing power can hardly pull a hill smells very rich fuel mix I had it scanned and misfire on cyl 3 history code poped up.
I replaced the plug after a HUGE ballbusting(lol) but the problem persists, my question is this I'm gonna replace the wires to see if that fixes it if that dosnt work does anyone have any sugestions or seen this problem? reading some of the other posts could it be the ignition controll modual
Joe
Old 01-06-2006, 11:11 AM
herkyhawki herkyhawki is offline
Re: Engine Problem
If it's a W code motor. You need to fix the CPI. Don't chase wires and plugs till you fix the fuel system.
Old 01-06-2006, 11:33 AM
Re: Re: Engine Problem
ok it is a "w" code motor what is the cpi
joe
Old 01-06-2006, 11:50 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Engine Problem
joe
http://www.automotiveforums.com/vbul...d.php?t=462726
Old 01-08-2006, 09:43 AM
Originally Posted by blazee
Ok Blazee I just replaced the fuel regulator and as suspected it was bad however the problem still persists sluggesh sort of bucking while accelerationg could it be fuel filter and if it is where is it located?
joe
Old 01-08-2006, 06:21 PM
biv343 biv343 is offline
Re: Engine Problem
It's worth a few bucks to replace the fuel filter if you haven't done it in the last couple years. Its on the drivers side, mounted inside the framerail, about halfway back (across from the transfer case). Can't miss it.
Old 01-08-2006, 09:19 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Re: Engine Problem
joe
When you pulled the plenum, was only one side washed, or were both sides?
Old 01-09-2006, 05:07 AM
Re: Re: Re: Re: Engine Problem
only one side was washed....passenger side
Old 01-09-2006, 05:41 AM
rlith's Avatar
Re: Re: Re: Re: Re: Engine Problem
It's quite possible you got a bad unit. Or it wasn't just the regulator that was bad. Other issues could be clogged EGR and/or fouled plugs. Since your regulator was leaking and dumping fuel you could have easily fouled the plugs and/or clogged the egr. I would also consider doing a full tune up...
Plugs
Wires
Cap
Rotor
PCV
Fuel Filter (every 15-20k)
Pull and clean the EGR (wire brush and carb cleaner)
Air filter
Old 01-09-2006, 06:35 AM
Re: Re: Re: Re: Re: Re: Engine Problem
Plugs
Wires
Cap
Rotor
PCV
Air filter
well ill check the plugs the egr was replaced in the summer im gonna replace the fuel filter this morning see wut happens then if thats not it check fuel pressure maybe i got a bad regulator dont no ill have to check i guess if all else fails
Old 01-09-2006, 09:10 AM
Re: Re: Re: Re: Re: Re: Re: Engine Problem
Well replaced the fuel filter still have the problem seems like longer engine runs worse it gets runs ok at idle but bogs down when you hit the gas pedal. Converter maybe? also i checked inside the plenium and it looks to be dry inside there?
Old 01-09-2006, 05:49 PM
Re: Re: Re: Re: Re: Re: Re: Re: Engine Problem
well i checked the plugs they all seem fine to me not fouled at all still wondering bout the converter?
Old 01-09-2006, 08:07 PM
rlith's Avatar
What did the plugs look like? How are the wires?
Old 01-09-2006, 08:18 PM
Re: Re: Re: Re: Re: Re: Re: Re: Re: Engine Problem
they were burning clean i dont no bout the wires im thinkin ok
