Go Back   Automotive Forums Car Chat > Ford > Contour
Old 01-06-2006, 06:56 AM
c.caldwell c.caldwell is offline
engine replacement
i have a 98 contour sport se with a 2.5,,,,, My question is what other blocks will interchange with this one
Old 01-06-2006, 12:03 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: engine replacement
3.0L duratec. Myself and many others on contour.org and newcougar.org have done the swap.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 01-12-2006, 12:28 PM
wafrederick wafrederick is offline
Banned
I have done one and the whole engine/trans comes out from the bottom.Make sure to lock the steering wheel,you will ruin the clockspring if you do not do this.
Old 01-12-2006, 01:07 PM
I pulled mine from the top and left the whole subframe connected. Just undo the motor mounts, roll resistors, and the misc connectors, hoses, and its good. It takes a little bit longer than dropping it from the bottom, but most people dont have access to lift.
"The CEG Nazi"
www.contour.org
