Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 01-06-2006, 05:29 AM
kyjohn kyjohn is offline
Question why cirrus why?
Why would my # 8 fuse blow sometimes when i turn the key and the next one i put in it may not?. The ignition,fuel,starter fuse will instantly blow and the car will not turn over. 1996 Cirrus may get sold cheap. I could use any help thanks.
Old 01-06-2006, 09:30 PM
alfonso alfonso is offline
Re: why cirrus why?
try using a next high amps fuse, example: if the fuse are 15 amps use a 20 amps. but the problem maybe are a bad contact in connections or short circuit you must be careful donīt try a highest amp fuse.
if the problem persist you need to call a car electrician to chek it.
Old 01-23-2006, 06:35 PM
rsublime4life's Avatar
rsublime4life rsublime4life is offline
Re: why cirrus why?
could be grouding out somewhere in the ignition
Old 01-23-2006, 07:37 PM
Re: why cirrus why?
it´s possible, the fuses are to protect the electrical system if a positive wire has a contact with the groud can burn up all the system.
