Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 01-05-2006, 11:11 PM
antnee69 antnee69 is offline
Unhappy 92 digital dash
first post here so be gentle -- i replaced dash that only had speedo with used one - all gauges seem to work when starting . tach-ok ,voltage- ok ,oil press- ok ,gas - full- but only drove 50 miles - ok , temp - nothing. temp shows "levels" when starting but then nothing .
temp sending unit maybe? wire not connected, and would this be same for gas if nothing happens? thanks
Old 01-07-2006, 01:37 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 92 digital dash
For the temperature gauge, it might be the sending unit or maybe the coolant isn't coming up to normal temperature because of a stuck open thermostat.
The fuel gauge problem may be the sending unit in the fuel tank. I had to replace one on my '97.
Old 01-07-2006, 06:33 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
if all the guages worked then failed in the first 50 miles I'd say you had a connection that wasn't tight enough and came loose. recheck all your conections that you made when replacing it.
