Go Back   Automotive Forums Car Chat > BMW > General Discussion
Old 06-10-2002, 09:00 PM
phoonrt phoonrt is offline
Sub install
anyone know how to install subs into a brand new 02 stock radio with a cd player-subs and amp--any idea where the rms cables go??
92 typhoon
02 325i
99 dakota R/T
Old 06-22-2002, 05:38 PM
92SCHNITZER 92SCHNITZER is offline
Thumbs down
You can wire any amp into a factory head unit via i high/low adapter they sell those at circuit city for like $39.99 they wire into your rear speaker leads and create a low signal for your amp w/interlink jacks and it will even create a remote turn lead in most cases if not then you can use the factory remote lead going into your factory amp which is in the trunk and readly accessible i would not change out the factory headunit because on factory speakers it will sound better than an aftermarket :flash:
Old 07-28-2002, 12:49 AM
JLuv_69 JLuv_69 is offline
I need help too!!!
Hey....I just installed two (10 in) subs and realized there is all metal on the back part of my back seat...... So therefore no bass is allowed in the cabin area.... Gets locked up in the trunk...... My seats does not fold down....I do have the ski slots which I already cut out...but still.....not much bass is alllowed..... I have a 99 BMW 328i..... anyone have any suggestion?????? Thanks!!!!!
Old 07-28-2002, 08:58 AM
You might want to look at the under side of the deck lid alot of times there are vents there to help moisture get out of the trunk in most cases you can enlarge the vents on the under side without anything beind noticed on the inside of the car removing the metal cover for the ski slot is also benificial you have to take the inner trunk liner out for it to be exposed but that helps :flash:
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
50 dollar sub install worth it? DIY? hardhousenrg303 Car Audio 8 11-13-2003 10:11 PM
Custom Sub Install in wheel well ! Jon_Blaze Car Audio 2 08-17-2003 07:05 AM
sub install? phoonrt 3 Series 1 06-19-2002 07:23 PM
Clarion deck and subs.. Installation! frogg Audio/Security 4 10-06-2001 09:05 PM
