Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-05-2006, 09:08 PM
romeorodeo romeorodeo is offline
a/c compressor so hot
I can hear a squeaking noise when I will turn my a/c on. Just few days ago it stopped blowing cold air. I only get the cabin air temperature circulating through my blower. I tried to switch it on and all i can hear is a squeaking sound under the hood. I tried to step on the gas forcing to make it louder so I could localize the noise then I smell a burning fume and a little smoke. I touched the compressor and it was burning hot. Now, I would like to ask help from the experts here on how to deal with this problem. thanks a lot in advance. My blower is still working until now,
Old 01-05-2006, 10:33 PM
Cat Fuzz Cat Fuzz is offline
Sounds like your compressor is seized up. The squeal and burning smell is probably the drive belt. The belt will melt down and break soon.
Old 01-05-2006, 10:54 PM
rodeo02 rodeo02 is offline
Yep, sure does sound like the compressor is locked up. Sometimes the belt will slip over the pulley, or if the compressor clutch is worn enough, the clutch will slip until it gets hot enough to burst into flames.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-06-2006, 02:36 AM
Re: a/c comressor so hot
Joel
Thanks for both of your reply. Another question. Do I need to change the compressor clutch too or other parts to solve the problem? I'm going to the shop tomorrow at least I know where to stand so the mechanic will not overcharge me.
Old 01-06-2006, 08:04 AM
Its probably a good idea to put a new clutch on there since the old one has probably been slipping and could be damaged.
Old 01-06-2006, 02:12 PM
ok. thanks cat! nothing more than that? i'm sorry i don't have enough knowledge about these things. i just don't want this problem prolonged. i want it done once and fast so to save money.
Old 01-06-2006, 02:42 PM
directory's Avatar
directory directory is offline
ok, anyone want to ask...?
why do you have the a/c on in january?
is it getting that warm in miami?? if yes...i'm coming down there to live with you for the next 3 months
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 01-06-2006, 03:33 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Actually supposed to be warmer in Denver to day then in much of Florida. With the humidity in miami I would probably be running the a/c too.
Besides, he has a '99 and even if it was cold and snowy the a/c would probably still be running. It comes on with the defroster setting.
They will probably replace the filter/dryer when they change the compressor. Usually a good idea to do that. Otherwise its just a matter of recovering the refrigerant, replacing the compressor, pulling a vacuum on the system, then recharging.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 01-06-2006, 07:39 PM
Re: Re: a/c comressor so hot
I just figured he was in South America or Equador or Australia or something.
Old 01-09-2006, 02:57 PM
Talking Re: Re: a/c comressor so hot
I bet if you want a hotter temp compared to your place then this is the place for you. That's the reason why this place is called the sunshine state.
Old 01-09-2006, 03:13 PM
So I went to the mechanic and he said the compressor is really dead. I have a friend who offered his wrecked Honda passport's compressor, he said its the same one. Anyone from you guys could confirm that it would fit?
Old 01-09-2006, 07:15 PM
Gizmo42's Avatar
I never understood that. Colorado actually has more sunny days per year then florida or california. We should be the sunshine state
As long as your buddies passport is the same generation (maybe other gens would fit too) and the same engine it should be the same compressor. Lucky you!
--Dave
Rear No-Slip Locker
Old 01-10-2006, 11:23 AM
mapua82 mapua82 is offline
I got a noise in my A/C compressor pulley bearing.
Since the A/C is fine i replaced the drive belt with w/o A/C
and i will return the original belt by summer.
I think if you're replacing the compressor yourself go with the used compressor, if you're paying for it go with brand new one.
