Old 01-05-2006, 07:31 PM
poopebay poopebay is offline
Can i drive stick shift?
I just got my civic yesterday. Had no clue how to drive stick. My car will like lunge back in for in gears. Am i just driving it worng? Maybe in worng gear?
Old 01-05-2006, 08:11 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Can i drive stick shift?
If it's a fairly strong movement, then you're probably shifting in a lower gear. Try to describe it and the situation better. Do you have a stock tachometer in your gauge cluster (so you can check the rpms)? When you shift and release the clutch, does the engine get louder or quieter? Is it just a kind of the engine bogging out, where it will go away when you accellerate more?
Old 01-05-2006, 08:59 PM
Re: Re: Can i drive stick shift?
Yea, it goes away at higher speeds. But feels like its just chugging back and forth. i think im hitting 3rd instead of 1st sometimes? I dont know.Should i have the clutch in when i turn> also if feels as if i must be at like 3-5 thousand rpm before i let the clutch go or else it will feel like itll kill.????
Old 01-05-2006, 09:16 PM
CivicSpoon's Avatar
There is no Spoon
Don't touch the clutch when you're turning, most of the time you should be in 2nd gear when you take a turn. Also keep your left foot off the clutch pedal when you're driving, even the slightest pressure will shift your clutch (and it will rub and eventually burn up). And never downshift into 1st gear if the car is moving more than 5-10mph. But it sounds like you're either shifting too soon (into a higher gear) or your clutch is gone (or both). If your clutch is slipping, it could cause the car to bog down until it gets grip (I have this problem with my car). but when you say it seems like it will die if you don't have it at 3-5K prms, is when you move in first gear to get the car going or in every gear?
Old 01-05-2006, 10:43 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Bad motor mount maybe?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 01-06-2006, 06:50 AM
my dad said it drives fine, i think i just suck at stick right now??
Old 01-06-2006, 06:56 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
one of the funniest post lol dude just ask ur dad what the technic is and go out and teach urself.. there is no better way to learning stick then by teaching urself and gaining the feeling of the clutch.. g/l
Old 01-06-2006, 07:41 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
i agree, takes getting used too, comming off the line i would be at a steady 2,000 rpms then slowly release the clutch till u feel yourself start to move, as ur moving forward keep releasing the clutch, but dont let ur rpms drop below 1500. oh yeah! thats if u have a tach. and one big key to this all.....practice practice practice.
The Evil Sleeper
Old 01-06-2006, 08:10 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
LoL... thanks for brightening my day.
Dude, you'll get it by the end of the week. If not you suck... haha.
Honestly, try learning to drive stick on an 83' Chevette with no hp, a fucked carb and a dead clutch. You learn heel toe technique with both feet... like this \ / to keep the car from dying while stuck in traffic. LOL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
