'90 Olds 98 Climate Control Fan
Hello, I'm brand new to this forum. I've got a prob with the climate control. I had it set on 72 degrees, on auto, and the fan was running at a lower speed, when all of a sudden it went to high speed. I was just about home so when i finally stopped, I pushed the off button but nothing happened. Tried that some more, tried the fan speed switch but still nothing happened. So I shut the engine off and removed the key, and the fan kept running. So I popped the hood and disconnected the battery and quit for the night. Any suggestions? Thanks
Re: '90 Olds 98 Climate Control Fan
the fan speed is controled by a semiconducter inside the duct near the
fan motor it has a thermostat and a heat sink. if it is stuck in the closed position the fan will stay on. i got a used one at the junk yard any gm car will do just bring yours and match it. |
Thanks for the info. I was searching through the earlier posts and found one with the part #, so I ordered it from GM Parts Direct for $88. It's supposed to arrive in 2 more days.
