Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-05-2006, 06:42 PM
studious03 studious03 is offline
whats possi
the tread title speaks for itself.... what is and what does it do.... i know its on the drive axle....
1993 Toyota Camry LE 2.2
1992 Chevrolet Caprice 5.0
1995 Jeep Grand Cherokee Limited 5.2
Old 01-05-2006, 06:49 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: whats possi
It locks both drive wheels so when you get on it both spin instead of just one.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 01-05-2006, 07:03 PM
dimefury's Avatar
dimefury dimefury is offline
posi is short for positraction it was a kind of limited-slip differential
go to howstuffworks.com and look at differentials and limited-slip differentials
here is a link-
http://auto.howstuffworks.com/differential.htm
Old 01-06-2006, 06:39 PM
HLandin's Avatar
HLandin HLandin is offline
My basic understanding of it is this:
An open differntial allows either rear wheel to turn faster than the other rear wheel while performing certain driving functions such as turning; however, with an open rear end, if one wheel looses traction, it spins and spins and spins while the one with traction hardly turns at all, resulting in the rear end fishtailing out (I believe this manuover on dry pavement is known as the "one-wheel peel").
With a closed differential, a clutch or other system limits how much one rear wheel can spin faster than the other, or locks the two wheels together which means that one cannot spin faster than the other. This means that you are less likely to fishtail with a closed differential.
Limited-slip is one form of closed differential. It uses a series of clutches to limit slip between the two rear wheels. This allows one of the rear wheels to spin a limited amount faster than the other (but not as much as an open rear end). As a result, you are less likely to fishtail with a limited-slip differential than with an open differential. This, in theory, can greatly help when driving rear wheel drive vehicles in bad weather (rain, snow, slush, etc.).
