Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 01-05-2006, 06:04 PM
1990_Executive 1990_Executive is offline
Send a message via AIM to 1990_Executive Send a message via MSN to 1990_Executive
Stalling Problem
Hey guys, I have a 1990 Town Car 5.0L. Monday I was driving down the road when the car stalls. It didn't sputter when it stalled, but it just quit running. It wouldn't restart either. I had it towed home. When I got home, I got in the car and it started fine. I drove it for about 5 miles no problem. Later that night I went to try and start it, and i wouldn't start, just cranked. I am getting fuel when it doesn't start.
Later in the week I was driving and it stalled, it didn't restart on teh first time, but the second time it started. IT was running rough when it finally started. After I got moving the roughness disappeared and it was running fine.
Last night, it stalled and wouldn't start back. I kept trying to start it, and I noticed if I held the key to the start position it would stay running and it would Rev up but only to about 2000 rpm. If I put the car in drive it would die. Finally I got it started and made it home.
Tonight I took the ignition control module out and had it tested. It tested out fine. I talked the guy at autozone, and he told me the ignition coil could also cause this. BUT, he also said a nuetral safety switch could cause the problem as well. Does anyone have any advice for me? All help is appreciated.
Matt
Old 01-09-2006, 08:31 PM
sreilly77's Avatar
sreilly77 sreilly77 is offline
Re: Stalling Problem
Matt
sounds like your loosing your spark from your spark plugs. that is usually caused by a camshaft position sensor. HOWEVER, if the car has a distributor, which i'm not sure if the 5.0L had or not, then thats your problem. i actually think you car does have a distributor. thats probably your problem most of the time you need a new rotor and a cap. get that checked out.
