Old 01-05-2006, 05:33 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Electrical Problem?
Alright i think i'm having an electrical problem with my eclipse, here's the story: I've had some electrical issues since i first got it. First off the speedometer doesn't work, nor do the gauge lights. Every once in a while when it was really cold here (like 0-10 degrees) it would start fine but rev up and down kinda wierd and sometimes die. Then sometimes it would stumble really bad and backfire, kind of felt like it was running on two cylinders. But it would usually only last a few seconds then go away. Now ever since monday it is doing the stumbling and backfiring all the time, except for about thirty second when i start it, it will be ok then the rpm's drop and if i press the gas it stumbles and backfires. I just got dsmlink and am waiting to install it cause if there is a problem with wiring i don't want to mess up the other ecu i have.
thanks,
EZ
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-05-2006, 11:41 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Electrical Problem?
check your plugs, wires, fuel filter, air filter, vac leaks, egr valve, make sure the MAS is connected, also make sure your wires are connected right. the coil side is 4123 and the engine goes 4321 (with #1 being closest to the timing belt)...as for the speedo not working, is the connecter on your transmission connted? it's near the rear mount.
Old 01-06-2006, 07:09 PM
ez1286's Avatar
It's weird it's not like an air sensor problem, or boost leak, I've done a boost leak test, check the resistence on the coils, and injectors, pulled the ecu "checked" that (pulled the cover off everything looks ok), plugs/wires are new, mas is new too, filter is good. It doesn't seem to be a mechanical problem because for a while it was intermittent (sp) and when i first start the car it runs for a little, before it would do the same thing but only when it was cold out. I'm putting dsmlink in tonight (the other ecu was ok so i should be fine) I'll see if that helps me figure it out. Thanks for the help.
Old 01-07-2006, 12:32 AM
MexRocket's Avatar
MexRocket MexRocket is offline
you never put dsmlink in scumbucket.. you went to bed
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 01-07-2006, 02:44 PM
ez1286's Avatar
Re: Re: Electrical Problem?
Yeah...I'm lazy, hey bitch have fun at traffic school.
Old 01-12-2006, 09:42 PM
ez1286's Avatar
Alright I somewhat solved my problems... Does anyone know what sensor would only be on for ~ 2 minutes 30 seconds after i start the car? My car misses and stutters for ~ 2 minutes and then it runs fine. Any ideas? I think this is during closed loop which would mean that it's not actually a sensor... Man I'm so damn frustrated I want to try my car with dsmlink!!!
