Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-05-2006, 05:00 PM
maryemar maryemar is offline
wipers only work on high
I have a 1997 Grand Marquis that the wipers only work on high also, they stop where they want to.
Old 01-06-2006, 06:46 AM
reekor reekor is offline
Re: wipers only work on high
Replace the turn signal switch.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 01-06-2006, 02:24 PM
raymerc raymerc is offline
Re: Re: wipers only work on high
This sounds like a motor problem.
Old 01-06-2006, 06:32 PM
Re: Re: Re: wipers only work on high
Where is the motor located
Also any suggestions on how to replace the turn signal switch if the motor isn't the problem
Old 01-07-2006, 01:22 AM
Try this test.
l Turn ignition switch to RUN.
l Turn turn signal windshield wiper switch to LO.
l Disconnect connector from windshield wiper motor.
l Check for battery voltage between Circuits 61 (Y/R) and 58 (W).
Yes
REPLACE windshield wiper governor.
No
CHECK for:
Open wire between turn signal and windshield wiper switch and windshield wiper governor.
Damaged turn signal and windshield wiper switch. SERVICE as required.
