Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 01-05-2006, 05:39 PM
jdq jdq is offline
oil change
Just changed oil to synthetic,boy you guys werent kidding about sludgy oil .People stay on top of oil changes that cant be good.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 01-31-2006, 03:10 PM
rimfire,22 rimfire,22 is offline
Re: oil change
jdq,
I've read about "sludge" in other web-sites regarding Durangos. I personally will always use a synthetic oil when ever possible. The only time I'll use a conventional oil would be when my pocketbook just won't handle it anymore. Regardless of the brand keep it up on usage of the synthetic oil and I beleive the "sludge" problem will dissapear. In addition change th oil at the proper intervals.
Good luck,
rimfire,22
Old 01-31-2006, 09:30 PM
TonyPa TonyPa is offline
Re: oil change
Hi, I just bought my 03 Durango. i was wondering about switching to a Syn....Is there a certain weight or brand you recommend?
I just got it, and haven't changed the oil yet, dealer says they did...but ya know how that is....
Old 02-01-2006, 04:40 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: oil change
Check your manual, use what is says, if it says use 5w-30 then ...
I use 5w-30 in my '00 CG 3.8l and 5w-40 in my '98 Cherokee 4.0l.
The Cherokee says to use 10-30 but I found that while idling for a long time when it was hot, the oil pressure dropped to about 10psi. When I switched to 5w-40 I had the same oil pressure cold but when it was hot it holds about 20psi and still goes to 50psi when the RPMS go up..
Old 02-01-2006, 06:45 PM
Re: oil change
TonyPa,
I match the weight of oil to my owners manual. In my case it says to use 5W-30 type. As far as brand is concerned to remain as practical as possible I think whatever brand you choose is fine. I won't matter anyway in price cuz they all are about the same.
Since you just got your Durango I'd wait til the engines broken-in before I start using a synthetic. Perhaps 6 months will due. I waited til almost 1 year for mine.
I usually take my oil to the dealership and have them use that. You could always ask if they could use the same oil as the one for the "Viper" as synthetic oil is standard for that model. I just don't know what the weight is so check them on that.
Later,
rimfire,22
