Old 01-05-2006, 11:45 AM
Neo851 Neo851 is offline
Clunkity Clunk
Whenever I accelerate or brake, I get a single "clunk" its not that loud but I can feel it in the floor.. Almost as though something is smacking the bottom of the floor.. I looked under there a while ago and didn't see much so I gave up but its getting more and more frequent... Any ideas?
1990 S15 4.3L 4x4 Jimmy
Old 01-05-2006, 02:09 PM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
U-joint maybe? Do you have a vibration with heavy acceleration?
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 01-05-2006, 02:25 PM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
Re: Clunkity Clunk
I had that a few times, check your caliper bushings up front, the ones that the caliper bolts slide thru.
Old 01-05-2006, 05:09 PM
kpmink kpmink is offline
Re: Clunkity Clunk
clunkity clunk,
my 2001 blazer did same thing...Ball joints needed replaced
and one wheel bearing...main cause ball joints, pitman arm....
Old 01-05-2006, 06:15 PM
diddy0071 diddy0071 is offline
Send a message via MSN to diddy0071
Re: Re: Clunkity Clunk
Originally Posted by kpmink
clunkity clunk,
Mine went, CLUNKITY-BOOM!
"I'm a jerk, not an asshole!!"
Old 01-06-2006, 04:02 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: Clunkity Clunk
Lift the tires off the ground and see if you can push the tire any abnormal ways . Check your engine mounts. watch the engine for movement while in gear while holding the brake .You got a few years on it now . I just replaced the ball joints on my 89.Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 01-06-2006, 11:13 AM
Re: Clunkity Clunk
Actually yes I do.. but I thought it was my transmission because the vibration only happens when the truck is in OD and not in D.. well not so bad in D..
She's old, she has almost 400lk on her but she refuses to quit!
Old 01-06-2006, 11:27 AM
792frank 792frank is offline
Re: Clunkity Clunk
Its probably the torsion bar mounts if its a 4 wheele drive, They cost about 15 bucks and there easy to change
Old 01-06-2006, 12:41 PM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
Clunking
I have the same exact problem with my 92 blazer, mechanic thought it was the u-joint. Replaced the u-joint and i can still hear it.
Old 03-31-2006, 12:01 AM
JIMMY92w's Avatar
JIMMY92w JIMMY92w is offline
Re: Clunkity Clunk
Does removel of torsion bars require a special tool? Or can the back yard machanic circumvent this need?
Old 03-31-2006, 12:30 AM
Rmbodie's Avatar
Re: Clunkity Clunk
A back yarder can do it . The dangerous part is releiving the pressure on the adjustment screw. My instructions showed using a tool similiar to a pully puller with two hooks . But it would not fit on one side because of other brackets in the way . I eventually used a floor jack that I removed the swivel pad from and installed a grade 8 bolt thru . then I jacked it up to the dimple in the torsion bar adjuster and releived it enough to remove the adjusting bolt and its block . I had the blazer on jack stands and lifted that side off the stands on the head of that one bolt on the jack . Carefull , lots of pressure . Rob
2005 Grand Prix.
