Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-05-2006, 11:26 AM
crzyCollegeKid crzyCollegeKid is offline
Post 1/4 mile time
Yesterday I went to the track for the first time with my new eclipse. I only got two runs cuz the place was packed as hell. My first run I won't even post because I wasn't paying attention, the tree caught me by surprise and many bad things happened. The second time around, I got into my track mode and made things happen I missed a gear which I quickly corrected, so I know I can do better. Here are the stats.
0759: My friend, stock AUTO 2001 GT, weight 3180
4882: Me, stock MANUAL 2003 GTS, weight 3250 (i didn't have time to take out my 2 12's)
------- LEFT ..... RIGHT
Car # ..0759 ..... 4882
Class ..Sport ..... Sport
DIAL ...
R/T ... .066 ..... .483
60' .... 2.412 ..... 2.568
330 ... 6.789 ..... 6.738
1/8 ... 10.395 ... 10.265
MPH .. 69.01 ..... 71.20
1000 . 13.460 ... 13.245
1/4 ... 16.062 ... 15.763
MPH .. 86.81 .... 90.00
We both fouled, but he fouled horribly, I was pretty close to a perfect .500 and I almost caught up to him at the end. I am pretty sure I can get it to go faster, mind you, this was my first time driving this car on the track and just by practice I was able to get my old prelude from 16.1 to 15.3. Anywho, tell me what you think and let me know what you've run. We both had our tires at 26psi.
PS: The weights posted are actual weights taken at the track w/o the drivers.
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 01-05-2006, 05:01 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: 1/4 mile time
thats an 'ok' time. you should be alot better with a manual GTS. you should be running low 15's. did you spin off the line? what rpms were you launching at?
Old 01-05-2006, 05:35 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: 1/4 mile time
ur 60' makes me think you either spun through or bogged, i try launching low ( 2k rpm) and carrying the rpm's only to 5500 or so, i was able to match my buddies' regal t-type off he line... that is until i shifted, so you can do a lot better w/ that car, 15.2 is the supposed track time so get to practicing!!
BTW did you pull that piece off your intake yet?
what tires are you running?
Don't act like you don't love it.
503/2000
Old 01-05-2006, 10:59 PM
Re: 1/4 mile time
i'm running the stockish BF Goodrich tires. I feathered out around 2k rpm, my buddies in the stands say i spun the tires a bit. i know my 60' is crap cuz like i said, i missed 2nd. and yea, i pulled off the lower intake air box and was running with the filter rubber-banded to the upper part of the box (i couldn't get an intake in time)
PS: I was shifting the moment the needle touched the redline, I was thinking of next time shifting into the redline right before the limiter(which means i have to find out EXACTLY where the rev limiter is), you shift before the line?
Not-named-yet:
R.I.P. Jessica
Old 01-06-2006, 04:23 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
You said you both fouled...meaning red light? Because your R/T is not -. Even if you both red lit...and you say your friends is worse, a .066 is not as bad as a .455. Dont run your car into redline because there is nothing left in the motor, and the rpm gain you will get after you shift would be lost in running the previous gear longer. Our peak HP is at about 5500...so anything after that is not gonna get you much.
and btw...how do you "miss" 2nd...i can understand 3rd maybe.....but ive NEVER missed 2nd gear. Dont mean to bash you, but it just sounds odd.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-06-2006, 05:03 AM
808drifter 808drifter is offline
Re: 1/4 mile time
mabye he let off clutch to early not miss shifted
Old 01-06-2006, 07:55 AM
cficare68's Avatar
cficare68 cficare68 is offline
Re: 1/4 mile time
I've done that before. Left off the clutch before I am in 2nd gear. I mainly miss when I go from 2nd to 3rd though. I really need to get some new shifter brushing. Right now though I am saving up to get my new clutch in. After that I might just have to take a trip to track and see what I can run
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 01-06-2006, 09:11 AM
Re: 1/4 mile time
even though most tracks have converted to the .000 r/t time....it seems that this track is still using the .500 as a perfect r/t. so the .066 is WAY early, and the .455 is very close to being perfect.
Old 01-06-2006, 11:00 AM
Re: Re: 1/4 mile time
thank you for explaining that for me much better than i ever could
oh and yea, about missing second, its exactly how they said it, i let off the clutch to soon and it got spit out, i recovered quickly, but we are talking 10ths of a second here
Not-named-yet:
R.I.P. Jessica
Old 01-06-2006, 03:18 PM
Sleepr awd's Avatar
Re: 1/4 mile time
second is really easy to miss too when you've got the stock shifter setup, if i pulled it too hard into second b4 my shifter and shifter boots i would miss, now i never miss
shift at 5600 if you shift after 5600 your wasting gas and too much b4 and u'll fall out of power, at least that's been my experience, my intake makes the engine more audible and as soon as 5600 rolls
around it starts to gasp
when your in 2nd and third you can shift at most 200rpm later than first
shifting at the right point makes a big difference
503/2000
