Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 01-05-2006, 10:34 AM
jahrastafari jahrastafari is offline
84, runs bad when it rains! HELP!!!
84 full size inline 6cyl, new carb, just passed smog!
Runs GREAT when its nice and sunny out!
Runs BAD when rain's or very over cast out!
barely starts in the driveway after a night of rain and when it does bad idle and 80% power loss when in gear/underload.....
PLEASE help!!!
AMBER - Thank you!!!!
Old 01-05-2006, 03:10 PM
Pesty351 Pesty351 is offline
Wink
Change your plug wires their arcing out
Old 01-05-2006, 03:36 PM
Re: 84, runs bad when it rains! HELP!!!
I WISH! Has Complete Tune, new rotor,cap,wires,plugs,no arc and good coil. Its NOT that Simple.
New Carb, Full Tune-up, Just passed smog 3 months ago..
Just WHEN ITS RAINS or CLOUDY it doesnt Run Like it Does on Nice Sunny Days with NO clouds.
When Cloudy Very hard start and under load has 80% power loss!!!
HELP!!! Must me SOMETHING with Dense Air and/or barametric pressure!!
HELP!
Amber -
Old 01-05-2006, 04:15 PM
Just becuase the wires are new doesn't mean one didn't touch a manifold and melt, one could be lose or cut, broke anything . The rainy weather puts more moister in the are and makes it easier to arc. I had a bronco II that did the exact same thing. I don't suggest find out the way I did though. (moving the wires with the engine running Zapp! Ouch!) What sometimes works is checking at night you can see the spark jumping to the block.
Old 01-05-2006, 08:40 PM
Re: Re: 84, runs bad when it rains! HELP!!!
nope - good spark on all wires and good coil - FOR SURE- no meltage or anything and i have gounded out the wires to check spark as well.
Its must be a MOISTURE sensor or some thing that deals with DENSE AIR imbetween the ECM and the Carb! NOT A MASS AIR FLOW SENSOR its only an 1984 INLINE 6 CYL with TFI ign.
ANYONE PLEASE HELP!!!
ONLY HAPPENS WHEN CLOUDY OR RAINY!!! PLEASE!!
Old 01-07-2006, 01:16 AM
jpanisiak jpanisiak is offline
I have an 83 that runs really crappy in the rain too, all it is is the moisture getting itot the engine, dont worry about it, its nothing harsh. Let the truck idle for a while before you start driving, i rev my engine up and if it keeps dropping to low rpms keep on the gas for awhile, it goes away(well gets better than it was). Just the moisture and water.
Old 01-09-2006, 10:50 PM
csparks78 csparks78 is offline
I don't know if you guys have met anyone that can tell if its going to rain because there knees or any of there joints hurt, but maybe your bronco is like that...... I'm sorry I thought it was funny. I've owned 2 bronco II's (87 & 89) in my 27 years and haven't experienced that.
Old 01-10-2006, 05:46 AM
66 p-51 66 p-51 is offline
check ur air intake, Idont know what it looks like but you may be sucking in moisture from inside the fender or somewere else. check ur heater hose for ur intake,pcv hose for leaksor inside ur intake on those days.
Old 01-11-2006, 07:42 AM
cougarman cougarman is offline
Get a plant mister. When the engine is running good, spray all the electronic components one by one. When one gets wet and the truck starts running bad, chances are you found the problem.
