Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 01-04-2006, 11:37 PM
dman679 dman679 is offline
Question Zx2 engine swap
I have been looking on-line everywhere for some info on swapping out my 2.0 w/ m transmission for something else (V-6), but nothing is comming out? Am I the first with this idea or am I just plain out of my mind? Is the Mercury Cougar V-6 compatible? Any info would be helpful. Thanx
Old 01-05-2006, 12:45 AM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
Re: Zx2 engine swap
its way to camped in the engine bay and the weight will throws off the balance of the car.
it sbenn thouhgt of MANY times, but everytime is realized to not bee a good Price vs Power mod, for th price of the swap, and all parts you can build a ZX2 that will make the same HP but more tq. and still have a better front end weight.
Which is why VERY few Zx2 swaps happen (one guy did a SVT focus motor just because he could)
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 01-05-2006, 06:16 PM
fwracer fwracer is offline
not to mention that the V6 in the cougar is a pos. Ive thought of doing a 2.3l swap that cosworth makes, but its not worth it.
fwracer
Old 01-05-2006, 06:47 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Zx2 engine swap
fwracer
you didnt just call a duratec a pos did you?
duratec < zetec, 4 cylinder duratec
learn something about the duratec before speaking BS
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 01-06-2006, 02:38 AM
Re: Zx2 engine swap
if ANYTHING the 220HP Zetec-R would be the best gain, but its like 6k from what i remeber and you have to see what tranny's you can use.
And its not US emissions legal.
Old 01-06-2006, 03:48 PM
Re: Zx2 engine swap
the zx2 trannys are junk. I already went through one at 80k. Any mods for that? The spider gears /differential just grinded apart. Its nothing like an import transmission.
Old 01-06-2006, 03:50 PM
Re: Zx2 engine swap
How about some quick mods to beef hp? All I've done is installed a K and N air filter. I'm dying to find out what wire to cut to eliminate the speed shut off too.
Old 01-06-2006, 03:51 PM
pre98zetec's Avatar
Re: Zx2 engine swap
there is no wire to cut, AFAIK to diable it, you need a chip.
-Josh-
Old 01-06-2006, 04:43 PM
Re: Re: Zx2 engine swap
its EXACTLY like an import tranny, its made by mazda and used in the Mazdaspeed protege.
solution...buy an LSD, but if youve killed a 5spd w/ jsut a K&N i suggest you learn to drive. People have over 200k on there tranny.
Old 01-06-2006, 04:47 PM
I wanna say White/green wire, but you need a switch as it will throw a code because the PCM is getting no speed reading.
this should also work on vct contours as there electrical for the motor shoudl all be the same.
Old 01-07-2006, 12:57 AM
Markb873 Markb873 is offline
Re: Re: Re: Zx2 engine swap
I may be quoting hot air but a buddy told me in his automotive school they got a V-6 from a Chevy tracker to work in a Zx2 I guess because its about the smallest V-6 around. You decide weather to believe him or not. I'm not sure myself if theres even a V-6 offered. Maybe suzuki had one in the Vitara. I'll just stick to Fords thanks.
Old 01-07-2006, 01:13 AM
edntrina edntrina is offline
Re: Zx2 engine swap
ZX2 Tranny's are junk? I can't speak for the auto but I've got 252K on my 5 speed with the original clutch and I run it pretty hard. The motor went before the tranny.
Old 01-07-2006, 02:08 AM
Re: Zx2 engine swap
I'm kinda pissed that I have to type all of this over again because I hit one stupid button....but anywayz. I say they're junk because of the cheap ass spider gears. I do know how to drive my car smart ass, anywayz. It was a rainy day and I pulled out of work and decided to turn the wheel and give it as much gas as I felt I wanted to. I threw out 1st 2nd and 3rd gear. They were junk and I barely made it home, never mind to the garage where I had to spend $1100 bucks to have a used with 30K put in to replace it. So, if you think that you zx2ners are invinsible, well, son, I got to tell you, try it on a rainy day and you will be in the same predicimate. The trannys do suck!!! I have a zr2 blazer jacked up, and I can cut that wheel in the snow, ice, rain and still be a crazy mf like I wanna and not have a problem with the tranny. Like a rock baby. So if you still have your stock trans, then you haven't driven hard enough. peace. no disrespect. -dan
Old 01-07-2006, 02:13 AM
Re: Zx2 engine swap
btw....white with green I heard it was right under the t-stat behind that little compartment that is useless. Thanx for the infor. later. -dan
Old 01-07-2006, 02:57 AM
Re: Re: Re: Re: Zx2 engine swap
the point is does the gains out weigh the cost?
if you mean v6 offered zx2? no
