Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-04-2006, 09:36 PM
highlandlake highlandlake is offline
Unhappy Oh great, now what have I done to this Rodeo?
'97 Rodeo 4WD auto 3.2 liter.
To the regulars, you may know that I've been attempting to self diagnose the rear ABS fault.
To everyone else, I've been trying to avoid paying $85 an hour to the Isuzu dealer.
Well, now I've pulled a beauty. After having no luck trying to get ABS codes by grounding the diag wire at the ABS module I've created a bigger problem. (I searched the archive with nothing close)
Now when I step on the brake, the dashboard and radio courtesy lights come on. Also the outside parking lights too. Also when the door is open and the brake is pressed, the door buzzer rings. When the left turn signal is used, all four parking lights flash dimly and the dash lights too.
Here's what is OK: All the exterior lights are working, no burned out bulbs, system works fine when headlights are on. Flasher works. Not a single blown fuse in either the cabin fuse panel or under the hood panel. The brake relay is OK, swapped with A/C relay to test. With engine running and accessories on it puts out 14.5 volts. No codes on OBDII.
Sorry for long post - what a bizzare one, huh? Any suggestions? I feel like a BOOB!
Tom
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 01-04-2006, 09:56 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Oh great, now what have I done to this Rodeo?
do you have a trailer harness?
If so yank it.
also, yank the ABS fuse and see what happens.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-05-2006, 01:24 AM
Ramblin Fever Ramblin Fever is offline
Yeap - yank that trailer harness.
I had one go bad 3yrs ago, had NO lights, period! No dash, no parking, no blinkers, you name it, not a one - and, worst of all, the trailer harness caused that short on an Arizona highway in pitch darkness doing 65mph.
Nothing's more thrilling then playing with wires and fuses over coffee in a truck stop at 2 in the morning
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 01-05-2006, 08:21 AM
directory's Avatar
directory directory is offline
wow, that sounds like fun
my heart would have been pounding and i would have been talking to myself alot..you know, like when you try to figure stuff out
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 01-05-2006, 05:43 PM
Thumbs up Re: Oh great, now what have I done to this Rodeo?
Darn, you guys are good. It WAS the trailer harness causing the problem. After work in the parking lot today I disconnected the harness behind the rear bumper. It was one of those HOPPY brand t-connectors. Problem now gone. Many thanks to you- I wouldn't have thought that I boogered it up by working up front.
'65 Chevy Malibu SS
'04 Ford Escape
GMC S-15 4WD
'51 Ford F2 pickup
Old 01-05-2006, 05:45 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
What is involved in removing the trailering wire harness?
Marc
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 01-05-2006, 06:06 PM
Re: Re: Oh great, now what have I done to this Rodeo?
TRUST me, there was a LOT of that ! But I wouldn't call it "talking"
1997 3.2L V6 Rodeo
Old 01-06-2006, 06:32 AM
Marc
On my vehicle it was as simple as separating the connection about a foot behind the bumper. But this also meant laying down on my back in four inches of fresh snow, while salt and sand fell in my eyes. But it was worth it, my bizarre electrical problem went away. Now I'll be looking for another harness to replace the one that was on there.
'65 Chevy Malibu SS
'04 Ford Escape
GMC S-15 4WD
'51 Ford F2 pickup
Old 01-06-2006, 08:50 AM
marcre's Avatar
Re: Re: Re: Oh great, now what have I done to this Rodeo?
thanks, I need to look into removing mine.
My Rodeo
Old 01-06-2006, 10:03 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: Re: Re: Re: Oh great, now what have I done to this Rodeo?
Yours might be different depending on what type they used. On '98-99 Isuzu put a plug for trailer wiring near the jack. I have a Hoppy brand harness that plugs into that, very easy to add remove that way. The previous owners of mine used a universal one though and tapped into the tail light wires. I removed all that to add the Hoppy one.
Open the compartment where the jack is and look inside to the left of the jack. If they used the factory wiring then there will be a white plug with 6 wires which go down through the body. If not then someone used a universal type which might be tapped into the tail light wiring, in which case there could be a number of way they did it.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
