Old 01-04-2006, 06:55 PM
irq_23 irq_23 is offline
Angry 95 S10 Blazer will not start, I am totally stumped
I have a 1995 S10 Blazer with 4.3l Vtech with the airfilter on the side. I was driving on the freeway and my car sputtered and died as though I was out of gas, although it wasnt. After I got it back to my shop I checked the spark and it was low, so I replaced the cap, rotor, wires, and plugs. Sparking great now but still no start. I replaced the fuel filter and checked the fuel pressure at the back of the engine at the schrader valve and it was puttting out around 56-60 psi, so the fuel pump is good. It has spark and gas so what the hell is wrong?!!? Help!
:::bang head:::
Old 01-04-2006, 07:05 PM
Just a thought?
Could it be my fuel pressure regulator? I am getting some washing on the passenger side when I look into the plenum. Would that keep it from starting? And if so how do I test if the fuel pressure regulator is bad?
Old 01-04-2006, 07:06 PM
LTBlazer97 LTBlazer97 is offline
Send a message via AIM to LTBlazer97
Re: 95 S10 Blazer will not start, I am totally stumped
:::bang head:::
When you turn the key to the run (not start) do the dash lights come on? Do you hear the familiar fuel pump whine? If not you may have a bad ignition switch. Just replaced one myself. If you do have lights and the fuel pump whine you can eliminate that.
1997 Chevrolet Blazer LT
Black 4x4x4 door
http://www.cardomain.com/ride/665593
Proud Founder of the "Clean, test or replace your MAF sensor club" Im also a member!
Old 01-04-2006, 07:15 PM
Yeah fuel pump starts up and dash lights come on fine.
