Old 01-04-2006, 05:36 PM
xplizit1 xplizit1 is offline
Unhappy inner tail lights
do you kno how i can get my innner tail lights to work on my hatch? the fuses are fine wen i connect em only the left light come on but not the back up lights or the complete right inner side. every wire is connected to the hatch tailgate but none oif the lights work except the left inner brake light. any ideas?
Old 01-04-2006, 06:54 PM
93CivicSiD16HB 93CivicSiD16HB is offline
Send a message via AIM to 93CivicSiD16HB
Re: inner tail lights
Not to sound like an ass but did you check the bulbs? Try taking the one that works and using it in the different socket(s). You should also check the wiring to the bulbs that arent working.
I know for some reason on my civic the seal wasnt good and the guy that owned it before me drilled holes in the tail light to let the water out. So it could even be moisture getting in the lamps.
Old 01-04-2006, 07:00 PM
Re: Re: inner tail lights
of course i checkerd the bulbs i even bought new ones. i checked the wires but couldnt find anything wrong. so i thought it would be a fuse but i didnt have the diagram. i got linked to one den checked the fuses all of em were excellent and had the right amps. i dont know wat the prob is. and i dont wanna pay a $h!t load to get it checked professionally.
Old 01-05-2006, 02:09 AM
raven262 raven262 is offline
Re: Re: Re: inner tail lights
Take a look at this pdf manual and figure out which fuse connects to the lights, then use a meter to check for continuity to the lights:
http://www.crxpower.net/~silverkorn/...ivicManual.pdf
Check pages 968 to 969 for a diagram. Quick question though, when did they stop working and what do you think caused this problem?
